Question about Cyberhome CH-DVD 300 DVD Player
No picture after resetting by pressing stop button for 20 sec
I lost sound (not picture) so I followed advice in these forums and I pressed the stop button for 20 sec which reset it. . I regained sound but then lost picture. I have tried repeated resets this way but still no pic. I have taken apart reconnected the video wires (component) just to be sure it is not due to poor connection but without benefit: ie it is not the wires. (there are no p/n buttons on its remote control either; I tried the other options in these forums of pressing setup and then sequences of green keys without avail).
Your advice is appreciated.
Problem fixed: I realized that the problem was that with resetting the player it defaulted to the standard video ouput ie no longer sending signal through the component video. I used a standard video cable and connected player to tv with that and it had a picture. Then I changed the setting to progressive output and got picture signal through the component cable again.
Posted on Aug 15, 2008
SOURCE:
Error code 5200 - What does it mean and how can I fix it?
It means that yo have a problem in your cartridge here are some steps how to reset your printer cartridge.
  • Power off the printer
  • Hold the stop/reset button then press and hold power (for 5 secs)
  • Hold Power and release the stop/reset button
  • Press the stop/reset button twice
  • Release power button
  • Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  • On the 3rd press the inicator should be orange.
  • Press the power button to set data
  • To set data remove cartridges then replace.leave for 20 or 30 secs
  • Press the power button again to shut down
  • Then press power button to power up.
  • The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset
Good Luck..
Jul 29, 2011 | Canon PIXMA MP180 All-In-One InkJet...
After replacing the ink cartridge printer still shows cartridge levels at 0%
Hi
You have to reset the cartridge
To Reset the HP Cartridges Works 100%
On the 3rd press the indicator should be orange.
Thanks
Aug 15, 2010 | HP Office Equipment & Supplies
Replaced ink cartridges but monitor still displays "ink low".
Hi, this fix worked for me (i've been wasting few hours on mp150 the first time, so if it soesn't work at the first attempt, don't give up and try at least few more times)
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Relase power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset.
Good luck, Peter
Aug 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How do I reset printer after putting ink cartridge in
To Reset the Canon Cartridges Works 100%
Relase power button
Please rate my rsponse!!
Jan 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Reset To551 ink cartridges
  • Relase power button
  • leave for 20 or 30 secs
  • then set language and counrty.
  • Then ink should be reset
Please rate my sesponse!!
Thanks, SF
Jan 28, 2010 | Office Equipment & Supplies
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Override alarm for color ink cartridge
Hi Redtail,
Try the following. It will not disable the alarm but will reset the in counter.
  5. Release power button
  9. To set data remove cartridges then replace.
  14. then set language and counrty.
  15. Then ink should be reset
Dec 04, 2008 | Canon MX300 Office All-In-One Printer
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Refilling of canon ink fine cartridge pg 41
Phew! Finally. This one works for my Canon MP140.
Follow all instructions completely or it won't work....
Relase power button
Apr 26, 2008 | Office Equipment & Supplies
Set up problems
Then it sems that you have set up your router with a different user name and passwd..the reset the router and the try to log in to the router and reconfig your router..
To reset the router, the best way is to press and hold the reset button for 30 seconds, or to press the reset button for 60 seconds..and for first 20 sec hold the reset with the power cable connected and for the next 20 sec with out releasing the reset button disconnect the power cable and continue holding the restet button , and after 20 sec reconnect power back and then continue holding the reset for another 20 sec..
and this would fix your problem..
Dec 01, 2007 | D-Link AirPlus DI-524 Wireless Router
Cyberhome CH-DVD 300 DVD Player Logo
203 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
