Question about Dryers
Frigidaire LC-240H-W*2 change heating from 240 to120
  • 10,319 Answers
The heating element is always 120 volts.
the two lines from the breaker box to the dyer consist of two 110 volt lines which one runs the motor and one for the heating element
Posted on May 21, 2011
Frigidaire stacked washer/dryer. Dryer quit heating. model # FEX831FOS.
Check the heater,thermostats,motor switch. Make sure the power is reading 240 volts
Jul 07, 2015 | Frigidaire Washing Machines
My frigidaire dryer GLEQ2152ES0 runs but no heat and the lights all blink
bad heating element check with multi meter first? check ur thermostats also. lastly may be not getting full 240 at the terminal block
Jun 09, 2014 | Frigidaire GLEQ2152ES Electric Dryer
I have a Frigidaire smooth top range. Burners heat, EOC as no power and thebake and broil elements therefore can't be turned on. I ordered and replaced the EOC. I am getting 240 volts from the wa
I'm assuming you're in the US, and the regular power outlets should have 120v AC.
Check your neutral at the power outlet. Between any of the 2 hot wires (your 240v) and neutral there should be about 120v AC.
If the neutral there is ok - check continuity between a white wire in a 6-pin plug on your board and neutral on the range plug.
If all ok there - check continuity between a black wire which connects to "L1" on the board and black wire from the power cord at the terminal block.
Good luck,
Vlad, First Choice Appliance Service in Sacramento, CA
Jul 06, 2012 | Kitchen Ranges
My Frigidaire Model LC-240 H Dryer will not start?
http://www.repairclinic.com/Dryer-Troubleshooting?red=#itwontstart_gas
Mar 05, 2011 | Frigidaire Dryers
Frigidaire FEQ332ES tumbles but does not heat up. Replaced the thermostat, did not solve the problem.
check ur breaker see if something is tripped dryer willl run on 120 but needs 240 to heat..
check ur element and also a thermal fuse, there might also be another thermosat that could be bad.
if gas check the ignitor, fuse, and thermostats
Feb 05, 2010 | Frigidaire FEQ332E Electric Dryer
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
My Frigidaire dryer has no heat. It was working fine last week and I could look inside and see it was ''red'' around where it was heating from the back part. 1 day later, no heat & no ''red'' ring in...
Check your breaker box. Dryer will run on 120 volts but will not heat without a full 240 volts. If that's not your problem, it's best to hire someone. I only say that because this brand of dryer is not easy to work on.
Nov 16, 2009 | Frigidaire FEQ332E Electric Dryer
Oven and burners will not heat up
have you checked your fuse/breaker panel for 120/240 volts and again at unit plug,sounds like you lost one leg of the 240volts and you only have 120volts and if its on the clock and timer side they will still work,but need 240 to heat elements fully
Jul 06, 2009 | Kitchen Ranges
Luquid crystal television set - 125-240 AC
You have basically 2 options available to you:
1) Contact Sharp at the address you listed and they will instuct you on what you need.
2) Purchase a power conversion transformer. This will convert the 240AC to 110 AC and you can use the standard 110 AC cord.
Dan
Feb 13, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How do you replace the fuse when your dryer tumbles but does not heat? it is a front load frigidare affinity electric dryer model LEQ700SE0
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
May 25, 2008 | Frigidaire Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
