Question about Whirlpool Pearl CS 63 True with Air Push Control - 103568-085
I have a Pearl Whirlpool bath. CS.63 with air switch. When I push the air switfch, nothing happens. It use to work, doesn't anymore. Water is plenty pull' Checked the GF ciurcuit breaker everything seems to be as it should be. Access is limited but am wondering if the pump has a resettable fuse button somewhere? Have seen this on other pumps, garbage disposals, Etc, Or if you have other suggestions.
  • 4 Answers
SOURCE: Air actuator button hard to push in.
the best plave for you to get a diagram is wholsey.. tell them name brand and size of your tub. and they should be able to help you.
Posted on Jan 13, 2009
  • 7 Answers
SOURCE: whirlpool corner tub not working
you wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
Posted on Feb 02, 2009
  • 19 Answers
SOURCE: How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Posted on Feb 09, 2009
  • 50 Answers
SOURCE: Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
Posted on Feb 26, 2009
  • 423 Answers
SOURCE: Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Posted on Mar 31, 2009
My on off button quit working on my bath jacuzzi. I can go out to the garage and trip the breaker to turn it off and on. I used to be able to barely push it and it would come on or go off, now you can...
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Oct 25, 2013 | Jacuzzi Whirlpool Bath Tub Real EG85-969...
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Air push button activates the pump when pushed down but pump stops when I let off the button.
It could be a number of things. A faulty hose situation or the switch are most probable. If you have access to the switch area, you can try to do a visual on the hose to make sure it is fastened well. You may get very lucky and find the hose (through time) has moused its way loose.
If you have a meter, you can go much further.
Apr 15, 2011 | Whirlpool Pearl CS P6 True with Air Push...
We were watching tv and all of a sudden the pump started running on our whirlpool bath, whats going on. We had to shut the circuit breaker to stop it.
Sounds like the circuit board in the system has had a voltage spike and cause it to go out. What is the model number of the pump with the circuit board?
Dec 17, 2010 | Whirlpool Pearl CS 53 NS True with Air...
Feb 07, 2009 | Whirlpool Home
Kohler whirpool tub will not turn on
Here is the manual for the tub. The switch is an air switch with tube. You have to make sure the tube has no holes in it or replace it if you can. look on the manual it will help you out.
http://www.us.kohler.com/onlinecatalog/pdf/1010564_5.pdf
Dec 14, 2008 | Kohler 1263-96 Folio 5.5' Drop In...
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Whirlpool Pearl CS 63 True  with Air Push Control - 103568-085 Logo
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
