Question about Irons
Re: Where to purchase cap on generator resevoir
Dear Sir or Madam,
I just purchased a used Rowenta DG050 Superpress Steam Generator Iron and it is in route as I type this question. The screw off cap that is on the reservoir; one side of it has a slight crack and eventually this will wear out. Can you tell me where in the state of Ohio, can I purchase a replacement cap to this reservoir? I live close to, Cincinnati & Dayton, OH. I didn't want to wait until it breaks, then run around to try and find this. Your assistance with any info you provide will be greatly appreciated.
D. Jamiel
debrajamiel@yahoo.com
I HAVE DG050 BUT STEAMER NOT HEAT HEAT ENOUGH TO STEAM THE WATER
Posted on Jan 28, 2009
Rowenta steam generator iron will not shut off the steam (continues to steam until resivior is empty)
see the pictorial, and proceed according
clean the mechanismo +passages+examine steam component for loose, worn, or broken and replace. God bless you
Sep 06, 2012 | Rowenta Steam Generator DG050 Iron
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
My steam iron does not produce steam it heats up good but no steam comes out
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 29, 2010 | Rowenta Steam Generator DG050 Iron
The plate of my rowenta steam iron needs to be cleaned?
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Dec 29, 2009 | Rowenta Steam Generator DG050 Iron
DG050 Rowenta how do you clean out the base(where
If you live in a hard water area add a bottle of kettle descaler and some hot water , leave for 1 hour then rinse out thoroughly
Aug 21, 2009 | Rowenta Steam Generator DG050 Iron
I need to purchase the thermostat/steam generator that is inside the water tank of the rowenta dg050 iron/steamer. where can i find that part? i know it is the problem
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Aug 09, 2009 | Rowenta Steam Generator DG050 Iron
My rowenta professional iron drips, how can I fix it?
Are you using distilled water to refill your iron? Distilled water can cause drips if used all the time. Refill with tap water and see if the drips stop.
Jun 22, 2009 | Rowenta Steam Generator DG050 Iron
Can't find a part for my DG050 Steam Generator
you can buy them at any electrical store or some hardware stores would have them... take the wire in with you (lablel where each wire goes in the switch or draw a diagram first) or take the whole iron with you. they crimp onto the wire
Mar 18, 2009 | Rowenta Steam Generator DG050 Iron
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Irons Logo
124 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
