Question about Sony PlayStation Portable (PSP) Console
Internet when i try to connect to the internet using my slim it freezes while loading and shuts off , why is this
    Problem Solver:
  • 6 Answers
Have you entered all your internet details in correctly? or have you done a quick search and found the interenet your using to connect to, and set it up without using a WEP key? if so try using someone elses internet and see if the same happens if it doesnt then what i would recommend is to reset your home interenet router and try to connect, but if the same happens again, if its under warrenty try getting it fixed
Posted on Aug 23, 2008
Ps2 freezing games
I was experiencing the same problem on my ps2 slim scph-90004. When I put a game in my ps2 it loads but after some time it just freezes at the same spot.I went to many shops but they dont recognize my problem.Then i open my ps2 slim (Warning:Opening of ps2 my void your warranty) and saw the lens which was not adjusted. SO,if you are experiencing the same problem then use the above method(For slim only).Look at the rod near the lens which has two small clips on it. Open the screws on the clips and take out your ps2 lens.Clean it with a cotton.Set the lens in some different position and load your games .
Apr 20, 2013 | Sony PlayStation 2 (PS2) Console
Tip
How to install emulator application on psp slim. requirements: a.emulator. b.psp...
requirements:
a.emulator.
b.psp slim with cfw 3.71 m33 or higher.
steps:
1.source out an emulator in the internet e.g. psp-hacks.com (in this case,emulator chosen is NesterJ NES Emulator 1.11 RM).
2.go to psp-hacks.com main page,then click on PSP downloads,then click on Homebrews,then Emulators, then Nintendo,and finally click on NesterJ NES emulator 1.11 RM.
3.source the emulator.
4.for psp slim,you must use applications/emulators that are 3.XX fw otherwise,it will not run on the slim.1.50 fw is for fat psp's.
5.to know that it's 3.XX and therefore for slim use,an emulator or application has basically one main folder upon extraction via winrar to your desktop,unlike 1.50 that have two main folders (one of the folders has a percent sign on it usually).
6.many emulators and applications will also indicate whether they are for slim or fat use.
7.connect the pc to your psp through usb connection and go to the root of the memory stick.
8.now copy the NESTERJ_1_11_RM folder from your pc desktop to the GAME folder in your memory stick like this - F:\PSP\GAME.
9.at this point you can load a legally acquired rom game to your emulator by placing it on the ROM subfolder found inside the NESTERJ_1_11_RM folder.
10.disconnect usb connection,then go to the game submenu on your psp,click on the NesterJ emulator application you just installed to run it,choose and click on the ROM/ folder to load the rom and there you go.
on Jan 24, 2009 | Sony PlayStation Portable (PSP) Console
I have a PS3 slim console and it is having some internet problems that I cannot figure out. I have a CAT-5 ethernet cable plugged directly into my modem which is directly connected to my PS3. Many times...
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Nov 07, 2010 | Sony PlayStation 3 Slim Black Console
I just bought the Acer 17.3" Aspire AS7741Z-5731. My problem is that the computer keeps freezing while connecting on the wireless to the internet. The network is set up right. I went into safe mode to...
Connect to the internet router using a patch cable. Goto support pages of Acer and search for an updated driver for the network card. Download and install. Now try again.
Oct 15, 2017 | Acer Aspire AS7741Z5731 Netbook
Using gmail causes my internet to freeze. it takes ages (and often needs refreshing) to load and then selecting "compose msg" or opening an email will cause the browser to freeze and then have to be shut...
Try to optimize your browser like deleting your cookies, temp files and folders and history. You may also try to disable some startup items in the system configuration utility window or run sfc/scannow in dos
Mar 28, 2010 | Google Gmail
Very long loading times on ps2 slim!!!
Try using a good quality dvd cleaner first. A dirty lens is usually the problem. Also check your game discs for any scratches as scratches also can cause this problem. Good luck and hope this helps.
Sep 11, 2009 | Sony Champions of Norrath: Realms of...
PC (Laptop) freezes when connecting to internet
You can try updating the drivers and check for firewall settings. Try update Anti virus s/w regularly
Jun 26, 2009 | Acer Aspire 3103WLMi Notebook
Palm freezes when trying to connect to internet
It could be related to DNS, in which case you will need to address your network settings, but on a Palm it is more likely a memory/ software issue. Try using something like AvantGo which caches pages locally to make sure that the device has the memory and capability to actually use the pages your trying to load. Then diagnose whatever browser your using possibly reinstalling it.
Feb 13, 2009 | Palm TX Handheld
Cannot connect psp slim into the internet (continuation)
Ok, it could be the wifi card has come loose a little but IS STILL connected, so when the psp tries to access the cards function, it fails and the psp freezes and shuts down.
Hope this helped!
Feb 07, 2009 | Sony PlayStation Portable (PSP) Slim...
Freeze-up
Have you tried other discs? Try copying the disc into a DVD-R and see if this works...I've tried this solution personally on my modded PS2 Slim and it worked fine...hoped this works for you too...
Jul 23, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
