Question about John Deere 50 60 70 520 620 720 Power Steering Plate
Where is the battery located on a john deere tractor
  • Canwoodjc
    Canwoodjc May 21, 2011
    which model ?
    normally they are under the seat on smaller models,, if its a larger one look at the starter and follow the positive wire back to the battery
  • 8 Answers
SOURCE: ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Posted on Feb 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
Sep 25, 2017 | John Deere Garden
Where are the transmission drain plugs on a john deere 2020 tractor
It is located on the bottom of the transmission reservoir, and that is 1 foot to the right from the battery.
Oct 21, 2013 | John Deere Seat 4210 4310 4410 4510 4610...
How do I replace a hydraulic pump on a John deere 1050. Where is it located?
The pump is located in front of the engine.A coupler joins it to the front crank shaft pulley.
Nov 06, 2009 | John Deere Steel Chain/farm/tractor/john...
Battery location for sound on john deere utility tractor
The only John Deere tractor listed on Peg Perego's website shows that there is no sound. Are you sure the one you have was advertised with having sounds? It so it may help to have the model.
Oct 31, 2009 | Peg Perego John Deere Utility Tractor
Main fuse for jd stx 38
Go to the web site (yesterdays tractor.com) then go to john deer message board they can tell you everything you need to know to get the right one and where.
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Where is the fuse located on a childs john deere ride on tractor
there is a thermal fuse under the blue plastic of the battery and and another thermal fuse in between the battery and the foot pedal
Oct 01, 2009 | Peg Perego John Deere Gator HPX Ride on...
Need help finding the PTO and the solenoid in a 445 John Deere Lawn Tractor. Diagrams prefered. Thank you for your help.
PTO on tis machine is located inside of trasmission,switch on dash.Solenoid/coil is located on rear of trans at the top.When energized the coil magnetically moves a valve inside of trans an allows high pressure fluid to engage clutch.In 15 years with Deere I only had too replace 2 solenoids and no clutches.
Sep 18, 2009 | Garden
Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Garden
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
UNABLE TO FIND RECHARGING OUTLET ON KIDS RIDING TRACTOR
The peg perego battery for the gator is located under the front behind the black gril.
If you have any additional help I would contact http://www.shopjandl.com/
They always help me with my ride on toys.
Jun 07, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere 50 60 70 520 620 720 Power Steering Plate Logo
126 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
