Question about Kitchen Ranges
LG French door refrigerator with bottom freezer LFX21971ST The top plastic shelf in the freezer is iced up and will not open. The left side of the shelf is completely iced up and stuck to the white plastic wall behind it. How can we manually defrost the bottom drawer freezer?
  • Kitchen Ranges Master
  • 2,605 Answers
Welcome to FixYa.
Based on the info you'll provided (including the model number, thank you...it is most important and saves unnecessary back and forth dialog) the first step is to thaw the ice build-up in the freezer.
To do this can be done several ways including,
**Unplug the unit from the wall before performing any service...safety first**
1) unplugging the unit for a period of time until it melts...not usually a feasible option since everything will thaw inside.
2) Using a hair dryer or paint stripper as a heat source and applying it to the frozen area...also not the method I prefer since the cabinet is mainly plastic and easily damaged.
3) Using a "steamer" and blasting the frozen area with steam...this is the method I prefer and what I use in my daily service practices.
Most household steamers can be used (if you own one) since they typically have a long hose attachment and nozzle that will allow you to reach the frozen area and melt the ice...though it can be somewhat messy and require some towels close by, but every method here will require that since water will be present from the thaw.
This is an example of the device I'm speaking of in the event you are not familiar with them.
I actually carry a small industrial one in my van, but this is the residential type many folks have in their homes.
Hope this info helps you move forward in getting the unit thawed. Good luck.
Once thawed you should investigate further as to what may have caused the ice to gather there to begin with. Was a door left open slightly at any time, etc ?
Regards,
Macmarkus :)
Posted on May 21, 2011
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Water tastes bad from LMX28988 refrigerator
This is usually attributed to the filter needing to be replaced... once a new filter has been inserted it should clear up the taste problem.
Apr 19, 2014 | LG LFX21971ST Stainless Steel Bottom...
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Nov 15, 2010 | LG LFX25975ST (247 cu ft) Side by Side...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Jun 09, 2009 | LG LFC25760 French Door Refrigerator
Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Oct 12, 2008 | LG LFX25960ST Stainless Steel French Door...
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
