Question about GE Profile Prodigy WPSE4200A
Front Panel Removal
My washer has been leaking water on the floor. There is no visable leaking coming from any of the connections in the back. I had a service man out and he told me that we have been overfilling it and to not put too much clothes in it. That has solved the leaking problem but now there is a terrible smell coming from it. Can you tell me how to get the front panel of the machine off? I want to see if there is standing water in the bottom panel as the source of smell.
  • 725 Answers
Slide a putty knife in about an 2 inch in from each corner pry the clips up and pull the front off.
I think you where misled the washer will auto stop fill when the pressure switch in satisfied...if it is working then you can't make the washer leak water on the floor no matter how much you put in it,,
There is a small Tube that goes into the pressure switch at the left side it may have came off.
also it may leak from the a cracked outer tub.. they are very thin plastic ...
let me know if I can help...
I sou
Posted on Aug 15, 2008
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
My Maytag Neptune MAH5500B has water leak problem. The water leaking out from the washer to the floor is clean and clear. So, I do not think it is drainage problem. I opened the back panel and did not...
Is the boot completely secure and not ripped or torn? The boot is the grey seal-like area that covers the drum. If it is torn at all, the water from whatever cycle, depending on when the water seeps through will end up on the floor.
Apr 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water leaking from front right corner - not hoses
The leak is coming from the area of the drain pump, but you will need to remove the lower toe panel directly below the door to sufficiently inspect where the leak may be coming from. The access screws are located under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. The following link explains what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Make sure you check all hose connections on the drain pump and make sure the drain pump reservior cap (if equipped) is on tight. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 05, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Water leaking from hot water connection
Try sliding the panel backwards it should slide off.. Hopefully this should do the trick
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Washing Machines Logo
90 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
