Question about Dryers
Need to know how to take the top of of a maytag dependable care quiet plus II dryer.
    Brigadier General:
  • 3,301 Answers
This blog by heatman will show you that , http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won if that doesn't help try this one http://repair2000.com/wpoolbelt.htm
Posted on May 21, 2011
Maytag dependable care quiet plus ii
Hi, The belt should be in a straight line from the motor to the drum.
If alignment is not corrected damage to belt may occure.
Normally if all parts are working properly the belt should align itself.
Make sure that belt is not rubbing on any other parts. (slowing motor down). Lube all moving parts with lube oil. Don't put oil on belt.(only on bearings of motor and drum).
Jan 20, 2014 | Dryers
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
MAYTAG QUIET PLUS II DRYER IS SQUEAKING
It seems to me you need a new belt that go over and around the drum in witch you put the cloth first you have to go on line and find the rubber belt to replace it, may need make and modle or part number. you will have to take the top off first by removing the screws and then the front panel - the front panel has the electric on/off switch connected to it so be careful not to pull it apart. The rubber belt fits around the drum and then is attached to the pulley/drive motor. have a vacume handy to clean up the worn off pieces from the damage belt. Reattache the front panel and top of the dryer.
Dec 25, 2012 | Dryers
I have a Maytag Dependable Care Quiet Plus II Heavy Duty dryer. The vent fan is loose on the shaft. What needs to be done to fix it?
Must replace it cause there is a flat side on the shaft and the blower wheel matches up to it and rounded out the plastic. Take off front panel and take out the screws around the wheel to get the metal plate out of the way then it either screws on or has a snap ring and a clamp to take off now wiggle the wheel to slide it off. Install new wheel and put back together.
Apr 06, 2011 | Maytag PYE2300AY Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
Maytag Quiet Plus 2 dryer
I can't speak for which one is best, but I I can help you fix the no heat problem.
I am assuming it's electric heat. If it is, I bet the element has failed. If you know how to troubleshoot with a volt-ohm meter, I can walk you through the repair.
Let me know if you have the wiring diagram, or can find it on the appliance. Also let me know if you know how to read one.
Feb 01, 2009 | Dryers
Open Questions:
Dryers Logo
137 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
