Question about LG BD370 BLU RAY PLAYER
I upgrade s/w v3.886.01.20.after that some disc erreor show
SCANNER ERROR 15
Try stopping and restarting HW and WIA
1. open Start Menu and type in services.msc press Enter
2. 2 tabs at the bottom Extended and Standard, select Standard
3. Now look for the Shell HW Detect
Right click and select Stop
4. Find WIA) (Windows Image Acquisition) Right click and select Stop
5. Now restart both of those services by Right clicking and selecting Start
Jan 22, 2018 | HP Office Equipment & Supplies
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Canon 2202 can not work if shows E002-000? I need to resolve the error
This erreor shown when temperature not good.check thefusing conection port .replace fusing film
Nov 14, 2016 | Canon Office Equipment & Supplies
Upgraded firmware with usb now get no functions
I'm sorry. What is the issue with that? It closed and the unit shows it's closed. Please explain.
Feb 09, 2014 | Samsung Bdp1500 Blu-ray Disc Player no...
Need a firmware update for Pioneer elite BDP 05FD
The current firmware update for the Pioneer BDP-05FD is available from Pioneer: http://www.pioneerelectronics.com/PUSA/Home/Blu-ray-Disc-and-DVD/Elite-Blu-ray-Disc-Players/BDP-05FD . Click on the Firmware tab then download the .zip file (titled firmware upgrade). Extract the contents of the file.
Burn the .ISO file that is inside the .zip file to a new CD-R (or CD-RW) using your burning software. (If you have Win7, you can use the included burning software to do this. Just right-click on the iso in the file explorer and choose Burn Disc Image.)
Then check that the disc has the needed files and that the files are the correct size: DLfile.pkg 95.3Mbyte (99,942,480byte), .DLdiscidentifier.txt 93byte, DLdiscidentifier.txt 93byte (for v1.71)
Then put the upgrade disc into the player (work with the controls on the front of the player instead of the remote). Then wait until the disc ejects (do not power the unit off or unplug it). Remove the disc and then turn the unit back on. You should see various information show up on the screen that will indicate that the upgrade is in progress. If it doesn't give the prompts, then you may have an unreadable CD. Try burning a new disc at a different write speed (lower); try using a different burner/computer if problems persist.
I hope this helps.
Aug 05, 2011 | Pioneer Televison & Video
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
Camera open to erreor. unexpected erreor
try to replace the main camera..or replace the camera module
Jun 08, 2010 | Nokia N72 Cellular Phone
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
When i go to install OS, it shows that bios isn't acpi compliant
This errror coming from motherboard because your BIOS version is different as compare with new version, so download new BIOS for ASUS Intel 815E Chipset CUSL2-C from web site of ASUS there is detailed step of How to upgrade BIOS, you can upgrade BIOS by creating Bootble Disc otherwise you can Upgrade from OS.
I hope that this has been very helpful for you
Dec 12, 2009 | ASUS Intel 815E Chipset CUSL2-C...
LG BD370 BLU RAY PLAYER Logo
57 people viewed this question
