MY COMPUTER EVERY TIME SHOW ME MESSAGE LIKE FAIL BOOTING SYSTEM OR SOMETIME BAD POOL READER OR COD7 CAN YOU HELP ME
    Guru:
  • 868 Answers
Hi hasnater,
Basing from the info that you provided it shows that you are having issues on booting up and basing on the error you mentioned you are having issues possibly with your Hard drive in this case and you may need to replace your system Hard Drive to be able to boot again.
If ever you will be replacing your Hard drive make sure that you also have an operating system disc to be able to reinstall windows on your new Hard drive.
cod7 is an HDD error and is a bad Hard drive posbbile multiple bad sector on the HDD already.
I hope that this clarifies you concern.
Have a nice day,
mvincentc
Posted on May 21, 2011
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
Tip
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
on Feb 09, 2011 | Computers & Internet
The orange light shows on the computer and soon as I cut on the computer it loads then freezes please help me
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 17, 2011 | Compaq Evo Notebook N400c
Bad virus - computer won't do anything - no cursor black screen only. Please help
Hi, install a new Operating System.
  • Turn on CPU.
  • Turn off PC.
  • Turn on
?? Repair Option
Thanks.
May 16, 2011 | HP Pavilion Elite m9500f PC Desktop
My Laptop is Dellstudio15,When I swith on my laptop is showing error while booting it self is: Check date and time settings,System CMOS Checksum is Bad.Please help on this.
This error message means that its time for you to replace you CMOS battery.
CMOS battery is a small battery on the system board that provides power to the Complementary Metal Oxide Semiconductor (CMOS) chip, even while the computer is turned off. This chip contains information about the system configuration (e.g., hard disk type, floppy drive types, date and time, and the order in which the computer will look for bootable disks). The CMOS battery allows the CMOS to preserve these settings.
Hope this information willbe helpful. Thank you for using FIXYA.
Apr 13, 2011 | Computers & Internet
Sony vaio pcv-rz40c1b not booting
Remove the RAM and clean the RAM slot then reinstall the RAM modules in the Computer. You may look for the proper connectivity of the display.
If the issue persists then service will be required.
Aug 25, 2009 | Sony Computers & Internet
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
DATE & TIME changes automaically
For starters, thanks for the good description of your system!
If you feel up to it, turn off the computer and open its case, somewher on the motherboard you will find what looks like a watch battery, you may want to start with replacing that battery, - take it out and go to your local walmart or general store and find the same model battery, this should help with the computer loosing time and settings, also if the system is rebooting while starting up I would first take a look at the memory in the computer. Has more memory sticks ever been added to the system, if so you may have two or more memory sticks that are not play well with each other, or you may just have a bad stick of ram. I would test this thory by replacing the RAM sticks or try booting by just using 1 stick of ram and see if the problem still occurrs.
Hope this helps.
Jun 18, 2008 | Intel Desktop Board D815EEA2 Universal...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
