Question about Cycling
How do i straighten the handle bars to line up with the wheel on a DUNLOP EDGE BMX 20 INCH RED CYCLE 360 GYRO BICYCLE, is it the nut right at the top
  • 4,336 Answers
What you do is ease off of the jamb fastener, which is the bolt at the center of the stem. Crank off a turn or two, and straighten the bar assemble. Then retighten the bolt.
Posted on May 21, 2011
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
I am wondering where I can order a back wheel for the mongoose 20 inch outer limit boys bike. Accidently got run over and is very bent. Thank you deb
Any Mongoose dealer or bicycle shop should be able to handle that or just web search for a 20" BMX wheel. It doesn't appear to be unique.
Sep 13, 2011 | Mongoose Outer Limit Boys Bicycle Pad Set...
How do i straighten the handle bars as they are out of line with the wheel on a bmx dunlop kids bike?
there should be a nut at the center of the bike handlebars, Loosen that , hold the wheel in place, and move the bars to the desired position , and re tighten the nut
May 21, 2011 | Cycling
The handle bars keep moving from left to right, how do I stop this from happening.
There should be a nut at the end of the handlebar stem, where it goes into the bicycle frame. The nut fits around the stem and screws into the frame. Tightening this will solve the problem
Dec 31, 2010 | Huffy BMX 20" Boy's Rock It Bike
How to fit a odyssey g3 gyro set
Hi MonkeyManTim
Firstly, remove the centre lock nut on the stem. This loosens the stem/headset. Pull the handlebars up and rest them next to the front wheel, make sure the brake cables aren't being stretched too much.
You'll see there is a locknut on the headset (at the top of the frame/top tube where you pulled the stem from) and loosen this (might need a massive spanner!).
Pull offthe toppart of the headset, ball races and lower part. Replace with the gyro bottom and top parts. Grease the ball bearing if they aren't already!
Slide it together, fit the stem and you'll notice the brake lines that come with it. Undo the rear brake, run the splitter cable from the front lever to the top half of the gyro, same with the bottom half. I found putting some padded stickytape on the bars helped here as the splitter cable would 'ting' off the bars.
Undo the front brake and run it through the stem hole, through the forks and cable tie it to one fork leg.
Test the brakes, adjust where necessary and on you go pulling bar-spins for fun. Please don't land a jump with the bars half spun, it hurts....a lot!!
Jun 22, 2010 | Mongoose 20-Inch Gravity Games BMX...
How do you adjust handlebars on mongoose fsg?
There are two ways to adjust handle bars on a bike. It's either by using a hex key at the top of the neck or loosening the octagon nut at the base of the neck near the body.
May 21, 2010 | Mongoose 20-Inch Gravity Games BMX...
We have bought a new bmx for ouf our son. we have had to build it ourseves but dont know how to set up the brakes. can you help.they are normal pad brakes.
Set the height of the pads and turn them so they line up with the rim. Next squeeze them tight against the rim with your fingers and then pull the lower end of the cable through to take up slack and tighten the cable clamp nut. Fine adjustment can be made at the handle bars.
Sep 26, 2009 | Diamondback Racing Team Dbr Sticker Decal...
Adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Aug 27, 2009 | Mongoose 20-Inch Gravity Games BMX...
I am having problems fitting my G3 gyro set to my BMX
yes bt i dont know how but there different versions for different bikes
Dec 26, 2008 | Odyssey Bike Bmx Gyro 1 1/8 " Rotor...
Cycling Logo
143 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
