Question about Classic Electronics Saws
My circular saw motor is producing blue sparks and so I have removed the cover to replace the 2 carbon brushes. There are 2 copper wires, one near each armature coil, which do not attach to anything at one end. My question is should they ? (and what are they for please ? ) Thanks for your advice !! Simon Shaw (I can send a photo if that would help)
  • 4,348 Answers
Well, if no one has caused this situation, you may be looking at a connection. meaning that these two wires connect to each other, and not also connected to something else.....a photo can help....
Doc
Posted on May 21, 2011
Testimonial: "I can send you a photo - where should I send it please ?"
  • Simon Shaw May 21, 2011
    One of the wires does seem frayed at its free end, though the one on the other side seems to have a finished end - where should I send a picture to please ?
A friend gave me a dewalt circular saw, the motor is running backwards, the wiring has been worked on, i noticed the *********** suppy wire is running directly into the motor housing
The simple solution is to take notice of the both carbon brush wires to the electric field change both IF YOU shure know that the electric field is mounted in the right direction , if the wires to the carbon brushes are having enough length then your problem is solved.
Feb 24, 2018 | Dewalt Saws
My circular saw is not working
Check brushes...
Dewalt Craftsman 2 Pack Carbon Brush Holder for Saws 147097 09 2pk
or sometimes the switch fails...
Craftsman 7621301 Circular Saw Switch
if you luck out, it may just be a broken wire, right at the switch, or right where it enters the saw? Pulling the, or directly on the cord vs. just the plug puts a lot of strain on the wires.
But if it is one of the parts above, very easy repair.
Apr 13, 2015 | Craftsman 7 1/4" 12 Amp Skill Saw
How to repair a Challenge Circular Saw
Brushes are very easy to replace, but it sounds more likely that your motor has burnt out. Try brushes first if you have already ordered them though. There are two types of brush fittings on saws.
1] There should be a couple of small removable caps at the back end of the motor, on opposing sides. Just unscrew them and you should see the brass contact plate of the brush. Hook the brush out, fit the new one and refit the cap. Now repeat on the other side.
2] The vent cover at the back of the motor should be held on with a couple of screw. Remove the screws and the cover. You should see a brush on either side of the motor, probably in some sort of removable holder. Just manoeuvre the holder so that you can slide the brush out and replace with a new one. The brush may be connected with a spade connector or something similar to either the field coil or the brush older.
When you run the machine after this, have a look in the vents at the same end of the motor and you should see slight to moderate sparking. This is normal, especially with new brushes. If you see thicker, brighter sparking from one of the brushes, this indicates that the field coil is breaking down. If the sparking is bright and running around the whole back of the motor, and you are getting a sparking/raspy noise, then I am afraid your armature is breaking down. Either of these faults will cause your brushes to wear very quickly, if the whole motor doesn't completely fail in the process, and I would recommend having the machine checked by a professional repair agent.
Jun 17, 2014 | Saws
How to replace brushes when they will not come out normally?
I had the same issue. Turns out the brushes were fused into the brush mounts. I pulled on the copper end cap and wire only to break it off at the carbon brush end. I had to pull the motor out of the housing (stator) to expose the brushes. I then used a tool to push the carbon brushes back in and out of the brush mount assembly. You could also push from the outside in, just make sure you get all the carbon pieces and use a tool that won't put scratches in your brush housings. My brushes where well over 1/2 inch long....but they were just fused into the assembly, so the spring wasn't pushing it properly against the commutator, which I am guessing was the reason my saw just stopped in mid use....I had ripped a straight line in a board and stopped for a few seconds to reposition the saw only to find it no longer worked.
Apr 28, 2014 | Makita 7 1/4" Circular Saw 5007NB
Extremely weak motor model 108526-01 remington
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Feb 12, 2014 | Remington Garden
Brushes arcing
Brushes arc for several reasons. If the spring over heated and lost its tension or the copper line from the brush to the cap broke/burnt off or the brush wore down too far to be pressed on the armature properly. The replacement brushes you need are Makita part number CB-124. If you still have exessive sparking after replacing the brushes you may have a bad commutator on the armature. The only way to fix that is to replace the armature, Makita part number 512831-0.
Oct 09, 2012 | Makita 5005BA 5-1/2 inch Circular Saw
New carbon replaced produces too much sparks making it hot
Either your new brushes don't meet up with the armature properly or the commutator is damaged. Brushes usually 'wear in' within the first couple minutes of running. If it's getting excessivly hot you most likely have bad armature contacts and need to at least resurface the commutator or replace the armature.
Nov 24, 2011 | Makita 9553NB 4" Angle Grinder
Sparking at the carbon brush of circular saw every switched on.
the armature is shorting across the commutator bars and a new saw will be cheaper than a new armature
May 21, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
How to install carbon brush
You have to open the case. First remove the transparent plastic on the side then you will see screws on the bottom part of the transparent plastic. Unscrew them and from there you will open the machine. Remove the rexair cover and unscrew the screw that attaches to the 2 carbon brush. When you remove the carbon brush you will see a spring and the copper wire at the end of the brush. remove it and put the new copper wire from the new carbon brush to the contact passing thru the middle of the spring. Then screw it back tightly.
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Skill saw has blue sparks when i start the motor
the brushes on the motor either need replacing or have dirt lodged in the carriers. Try using compressed air to blow it out first. If its a few years old it may need new brushes in the motor.
Jul 06, 2009 | Saws
Saws Logo
224 people viewed this question
Top Classic Electronics Saws Experts
Tom Chichester
ray gallant
Are you a Classic Electronics Saw Expert? Answer questions, earn points and help others
