Question about Quinny Buzz Three Wheel Stroller
I thin k the bearings have gone, theres a rattle from the back wheels?
  • Quinny Master
  • 1,629 Answers
Good Evening
How old is the product? If it is under 2 years old please contact your retailer with your proof of purchase to discuss this with them.
If it is a very new product can you confirm all packaging has been removed from around the wheels & their fixings?
Posted on May 23, 2011
Do you get a rattling noise if the rear wheel bearing is shot
I would jack the rear wheel up off the road and see if you can feel any play in the wheel bearing. It could be wheel balancing.
Jul 08, 2014 | Car Audio & Video
ENGINE RATTLES AFTER PUSHING THE GAS
Poss water pump bearing, grab the water pump pulley and see if it moves side to side and up and down, if so the bearing is gone.
Jul 19, 2012 | 1991 Ford Mustang
Back wheel rattles when u spin it back and forth and also vibrates when i pull the throttle back going along but its not the bearing in the rear wheel as theres no side to side wobble or play please help...
Sounds like a collapsed or near collapsed bearing. While rocking it from the top forward and back is a good indicator of bearing wear. So too are vibrations and rattles from the wheel. It could also be the anti vibrational cushions assuming your bike has those, that are present in the back wheel. They soak up the to and fro backlash that you would normally get when accellorating.
Sep 18, 2011 | Gilera Runner VX 125 Motorcycles
I have a 1988 1500 i am getting a noise like a rattle coming from the front wheel this is after i had a new tyre fitted checking the brake calipers i see that the right side is tight and the left side is...
The caliper should be bolted on tightly at the mounting points, but should float back and forth so the pads do not wear unevenly. Other things to check for odd front end rattles. Are your steering head bearings tight? That can cause rattling or knocking as well as handlebar shaking. A bad front wheel bearing can cause rattling or knocking (one side is bad and the wheel is twisting/rocking. Elevate the front wheel , grab it in the 10 and four position, and see of you can notice the wheel moving where the bearing hits the axle. Fork lower has worn out and the bushing is banging when it rocks. Rare but possible. Should see unusual wear on tube and movement wear tube meets lower. With wheel off , grab bottom of lower tube and top of lower tube check for movement.
Oct 08, 2010 | 1989 Honda GL 1500 Gold Wing
Rattle in rear
I've had both rear wheel bearings go on my 2003 Sedona. Both made this same rattling sound. It's about a $300 job.
Jun 27, 2010 | 2003 Kia Sedona
Afer being driven 5-7 miljes my 99 tauras loses
I would have to say your engine is probably shot. The bearings are probably gone. It is possible, i suppose, that your oil pump is faulty. As soon as the oil warms up, and becomes thin, the rods and lifters start to rattle. The same goes for the oil pump, as oil becomes hot, and thin, it may not be pumping properly. I would try a used oil pump, and see if there is any difference before i wrote the engine off.
Jul 27, 2009 | Ford Taurus Cars & Trucks
Front wheel bearings
Hi everyone19000 mls and the right hand side front wheel bearing is completely trashedflat bearings crumbling and totaly vapourised bearings. yes i do powerwash the bike occassionally,and i do torque the front wheel spindle to the correct numbers,the left hand bearing is OK,this is the second time the right hand bearing has failed,this time more dramatic than the 1st,no warning,no rusty watermarks, Still only £20 for new bearings and seals what the hell,nothing else has gone wrong,and she still rattles the rev-limiter. ,Here's a tip to make your bearing last a bit longer - applies to all bikes - remove the black rubber seal using a fine bladed screw driver, carefully prising it out from the centre. Practise on the old bearing first. Once the rubber seal is off just look a see how much (or how little) grease the manufacturers put in there - add some good qualilty grease. pop back the seals and fit. May have do both sides Works for dirt bikes and especailly if you pressure wash your bike. ,,,
Nov 10, 2008 | 2005 Aprilia ETV 1000 Caponord
Shaking and rattle sound at lower speed and when turning
sounds like worn front wheel bearings jack up car with both hands on Tyre see if there is excess movement if so replace wheel bearings
Nov 07, 2008 | 2003 Ford Expedition
Quinny Buzz Three Wheel Stroller Logo
161 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
