Question about Behringer Sx3242fx Eurodesk 32-channel Mixer New
Sx3242fx factory reset - Behringer Sx3242fx Eurodesk 32-channel Mixer New
My behringer eurodesk sx3242fx has a problem with the MAIN OUT XLR (L&R)....LEFT side is not working what is the problem?
Process of elimination needed...start by checking cables and amplifier channels. Also make sure the mic channel on the mixer does not have the left and right "Pan" control turned to the extreme "R" (no left output).
May 26, 2014 | Music
Reset euro desk 3242fx
What sort of reset are you wanting to do. Please give as much detail as possible
Mar 09, 2014 | Behringer Sx3242fx Eurodesk 32-channel...
The serial number to my makie onyx 2480 is missing the serial number on the back. how do get it
Some of these units will have a serial number on the INSIDE of the unit, but this is not likely with this unit. No serial number means the unit has been intentionally tampered with by someone.
Feb 27, 2014 | Behringer Sx3242fx Eurodesk 32-channel...
Eurodesk sx3242fx the fx started flashing then quit working, now it does not light up at all, what causes this?
They die, it's a cheap mixer and if you look around you'll find a lot of these with faults of one sort or another. They are not worth repairing due to the way they are made unless its under warranty. Remember if you registered it there should be a three year warranty.
Jan 28, 2014 | Behringer Sx3242fx Eurodesk 32-channel...
I imported a behringer SX3242FX today and it was working fine for about an hour suddenly I felt the digital effect that I selected( Delay ) has lost from the microphones and voices became dry.. Then I...
Is the number on the effects display still flashing? Can you select effects or is that section dead now? I've had occasions with my Behringer mixers where a bad ground or otherwise improper power supply seems to cause issues with the effects section but the board seems otherwise functional. It has definitely had me scratching my head a few times and is worth investigating.
Aug 17, 2012 | Behringer Sx3242fx Eurodesk 32-channel...
Behringer SX3242FX intermittently looses signal to the left main. When it's out, the the level meter indicates signal on the left, but not the right. This is consistent in both mono and stereo inputs....
Make sure you are using BALANCED cables from this... eithe XLR or TRS cables. Using TS unbalnced cables MAY ground out the signal which is sent as balanced. Here is a schematic for the 24 channel unit... yours just has eight more channels. http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
By looking at the signal paths, you can OFTEN do a lot of testing from the available jacks. If the contacts on the right main INSERT jack go bad, that would cause your problem,,, NEVER use other than an insert cable in these jacks.
Sep 24, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
I have a beringer sx3242fx, i need to know the best compatible amplifier to use my samson speaker that pushes up to 500 w
Almost any amplifier will work so there is no "best"... Just make sure the amp RMS rating is a bit below the RMS rating of the speaker for safety of the speaker. A QSC GX5 would be a candidate. You would use one side of it for each speaker if you have two, or use only one side for a single speaker. A lot of pro's seem to use these amps. USE BALANCED interconnections either XLR or TRS cables AND for sure power the amp and the mixer from the same receptacle... it often means running an extension cord like the pro's do to avoid ground bounce noise AND damage to the equipment.
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
I have a Behringer sx3242fx, mono input channel #2 mute button got stuck in (pressed in), i.e. the channel cannot be un-muted no matter how it is pressed. Any suggestions?
Put a tiny bit of CRC226 around it to lube the button. Then CAREFULLY use a scalpel to encourage it to come up. Then put a little more 226 around it.
Mar 28, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Eurodesk sx3242fx has the numbers 1 & 25 flashing in the effects processor display. where can I find the code to tell me what is wrong?
Hi ! I have the same problem. THERE IS DEFINITELY something wrong there. It's not that you've not selected the effects, but the units keep on resetting. Even if you can select a different preset, it will go back to 1 & 25. I've been told that the problem has something to do with the power source, but I'm still trying to get a solution. Best luck !
Feb 09, 2011 | Behringer Eurodesk Sx3242fx Mixer Weffects...
Behringer Sx3242fx Eurodesk 32-channel Mixer New Logo
109 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
