I cant join my wireless router with my iphone?
  • 65 Answers
What you want to do is go to your computer and make sure that your wireless router is discoverable because if its not your iPhone will not detect it also what you want to do is make sure that your iPhone's WiFi is enabled to do that go to settings WiFi and enable and remember when you try to connect to enter the password right and if all that doesn't work try holding the home and power button and wait till it turns off and boots up.
Posted on May 22, 2011
Iphone 5 withlg 4g lite tablet
#im asuming you want to use the internet on your table using the iphone 5 as the wireless router ?
if this is the case you will need to set up a wireless hotspot on your iphone by going to Settings--> Personal Hotspot set up a password and your off, on the tablet search for wireless connections and join the iphone after that your surfing on your tablet. be warned that this will seriously drain your data unless you have a high allowance
Mar 12, 2014 | LG Tablets & eReaders
NETGEAR WNR2000 reboot every time to join wireless devices
Are you saying if you hook up bring in the new Wi-Fi device you need to reboot for it to be recognized? Are using WPS?
Dec 10, 2017 | NetGear WNR2000 Wireless Router
My iphones and tablet are unable to join on my belkin wi fi why
Go ahead and do some investigating. Does connecting via wired LAN brings any results? Could it be that you're having 2.4GHz interference? Try switching your WiFi channel or moving your router away from large metal objects. If that doesn't work try connecting to your wireless network holding a device close to the antenna, inches away. Does this work? If so, your antenna or WiFi signal amplifier circuit could be dead. You can open your router up and do some further investigating with a multimeter, but if you suspect a hardware failure, it's probably best to not bother opening it up and checking up on your warranty options. Even if that doesn't work out, it's not like routers are super expensive these days.
Feb 22, 2013 | Belkin Surf N300 Wireless N Router
I cannot get a wireless connection with my iphone so backups don't happen
You probably need to make sure that your iphone and your router are both using the same 'standard' of wifi (wireless 802.11b, 802.11g, or 802.11n) The older 'b' and 'g' standards use 2.4 GHz frequency - The Newer 'n' standard can use 2.4 GHZ and also 5GHz for faster performance - I think the iPhone asks you to choose which frequency you want to use rather than asking you to type in 'b', 'g' or 'n'
Nov 12, 2012 | Linksys E900 Wireless N300 Router
I can access internet through wireless but cant access my iphone although it is conected with buffalo router but not accessing internet
I thought that the iPhone was connected to the internet thru IBM's cellular network, and did not
know how to talk to a wireless cable router at all.... note that the iPhone has no idea what
802.11n WiFi standard is... the iPhone uses 2 technologies to communicate with the AT&T network,
the iPhone 4G has two models, a CDMA model, and a GSM model...
IPhone reference: http://manuals.info.apple.com/en_US/iphone_user_guide.pdf
May 14, 2011 | Buffalo Technology Buffalo Wireless-N...
Trying to connect my iPhone 4 to my WGT624 v3 router. My iPhone is detecting the network, but i'm getting the message "unable to join the network" .
Hi chaps,
I did two things to resolve this issue
1. Downgrade the router to a lower version.If your router is Netgear WGT624 v3 use this link to downgrade your router
http://www.davejackson.com/life/cant-access-wifi-with-ios-6-on-iphone-with-netge ar-wgt624v3-fix/
(this help to avoid getting a errro message "Unable to join network")
2. Reconfigure you Wifi network by going to setting ---->under choose a network---> others-----> Enter your SSID name (seen at the back of your router) ----->under the security tab selet the same encyrption standard as that of your router which you can see when you log in to the router (usually router IP 192.168.1.1) ---->setup ------>wireless setting----> security option. This one helps you to join your home wifi as soon as you enter your home.
Dec 29, 2010 | NetGear WGT624 Wireless Router
When trying to connect my iphone 3g to the wireless router i am getting the error message unable to join the network USR5461 even though I am using the correct password. what do i need to do to correct...
I wonder if your router is set to perform MAC address filtering. If so, you have to either find the MAC address of the iPhone's wireless card and add it to your router's appropriate list, or set your router to not filter by MAC addresses.
Just my 2 cents... Carlos
May 13, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
I have a F5D8631-4 Router which works extremely well for the 3 computers in the house. I cant seem to connect my new iphone to the network. It keeps coming up with unable to join network. Ant ideas? Cliff
1.Login to any one of your computers
2.Open the router page
3.Change the Channel - 11 and SSID should not have space
4.Set sec for WEP or WPA auth as TKIP
5.Disable the WPS
6.In the Iphone forget all the old networks and restart the Iphone scan for WIFi and connect ...
Sep 27, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Why wont my 2wire router find my iphone anymore? It used to connect, nothing's changed on my computer or iphone but the wireless light is not coming on when the iphone tries to join network.
Has the router been reset recently?
If it has, this could be the issue. Check the installation instructions or website for known issues relating to this.
Hope this helps!
Jul 08, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
David Payne
David Payne
