Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Vaccume shuts off after 5 minutes of using. will only start after sitting for hours.
  • 4,348 Answers
This sounds like an overheat condition. You must have plugged air flow, so rather than cause a fire, the unit shuts down until cooled. Find and remove the blockage << Not always an easy task.
Posted on May 21, 2011
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
When vaccum is in use it shuts off after vaccuming for a minute .
Look to see if the main air filter is clean (some can be washed and others have to be replaced) it will if blocked up trip a thermal cutoff to protect the motor in the unit.
Dec 22, 2012 | Electrolux Lux 7000 Bagged Canister Vacuum
The vaccum just stopped working while in use
It's either plugged or clogged in the filter, which triggered the internal thermal shut-off. Clean it out and wait thirty minutes and it should work.
Dec 08, 2011 | Eureka 3041BZ Upright Vacuum
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Jul 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I HAVE A BRAND NEW HOOVER MACH-3 CYCLONIC THAT CUTS OFF EVERY FEW MINUTES. IT IS DRIVING ME CRAZY! IT'S LIKE AFTER 5 MINUTES OF VACUUMING IT HAS TO SIT FOR A LEAST AN HOUR THEN YOU CAN VACUUM FOR ANOTHER...
If it were mine and it was brand new I would bring it back and exchange it. It sounds like the motor is over heating and shutting off automatically. Does not sound good. My advice return it.
Mar 16, 2008 | Vacuums
Mach 5 hoover turns off
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Dec 29, 2007 | Vacuums
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
91 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
