Question about Bosch 500 HMB5050 Microwave Oven
Bosch HMB 5050/01 Microwave - Shuts down after 20-25 seconds and does not heat. Turntable moves, light comes on but it does not heat or stay on for the time set. Tried resetting outside breaker but no luck. Oven works fine.Not on Demo Mode. Help
  • 3 more comments
  • monteo
    monteo Jun 28, 2012
    Mine is doing the same thing, power reset did not change the results. Also, after sitting for several days unused, the time interval it ran before shutting down moved out to a couple minutes on the first try, then all subsequent tries were back to the 15-20 second runs. Air flow is constant via vents in the front of the built in unit.
  • Bonnie Wilson
    Bonnie Wilson Sep 17, 2012
    Mine is 13 months old and started doing the same thing last night. I rarely use the microwave and I'm VERY disappointed in Bosch as it seems this is an on going problem. I spoke with their service management people and got no where as my 1 year warranty ran out last month.
  • pradd20
    pradd20 Nov 01, 2012
    Our HMB0550/01 is also a 13 month old and started doing exactly same thing. Fortunatly we have an extended warranty. We called and the technician came as infomred us that the magnetron is bad. This magnatron allows heater to come on and also controls the timer. Seems like many people has issue with this model. I didnot get anywhere with BOSCH but my extended warranty with LOWS helped. Good luck.
  • tam le Dec 14, 2012
    magnetron is bad, I just got my fix.
  • Anonymous Mar 15, 2014
    Selected Demo Mode in error and now cannot use microwave as no way to exit this mode and go operational again
  • 710 Answers
I'm assuming this is a built in oven/microwave combination since you mentioned the oven works fine. On a stand alone microwave, we would reset it by unplugging and waiting at least 10 seconds for the microwave to reset itself.
Was the circuit breaker tripped when you reset it? When you reset the circuit breaker, did you wait long enough. Try turning the breaker off, then waiting a couple of minutes before turning it back on. Then give the microwave a try.
Another thing we run into with a built-in is that sometimes there is not enough air circulation. Check to see that the vents are clear and clean.
Good luck! Reply back if this does not solve the problem.
If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 21, 2011
Bosch microwave hmb 8050 What is this ? We saw an orange spark after removing the back of microwave to check door switch since microwave was shutting down after 4 seconds . Please help w diagnostics
Sorry, but If you don't know what you are doing with a microwave, I would strongly suggest you take it to a Technician who does. Microwave ovens operate on extremely high voltages. Apart from the radiation risk.These things can kill you if you touch the wrong parts during operation. Some components store electricity for a short time after you turn it off. One of the door switches is a safety switch to prevent people from forcing or trying to override the door locks. It will blow a fuse inside the machine immediately if the door locks / switches don't close or open in a set sequence.
Mar 21, 2017 | Bosch Microwave Ovens
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Why does the microwave have the turntable keep moving/light stay on/keep vibrating whenever the door is closed?
< - contact me directly for free advice.
Remind me of your exact symptoms and the full model number from the tag in the cooking cavity or elsewhere on the oven.
May 10, 2014 | Sharp R-530ES Microwave Oven
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
Microwave shuts off after 22 seconds
Any product that uses electronic parts is subject to failures. That's why warranties exist. Contact Bosch on their webpage to get assistance.
Nov 16, 2017 | Bosch 500 HMB5050 Microwave Oven
My Bosch microwave (built in HMB5050 has stopped heating all of a sudden. Everything else appears to work fine but it does not heat. What is the problem?
I have the same issue, plus mine shuts down after 30 seconds. There are a few other similar issues on here, with solutions including unplugging it for 10 seconds, replacing a fuse, and replacing half the internals. Please post your fix if you find one!
Jul 28, 2011 | Bosch 500 HMB5050 Microwave Oven
Over the last week the light on the inside of the microwave has dimmed and now it doesn't come on and the turntable doesn't work. Will replacing the light bulb correct the problem? Somehow the microwave...
I think you very possibly have a 2 part problem. Firstly, replace the lamp assembly, then replace the turntable motor. If you have a little electrical knowledge, place a tester on the turntable wires when microwave is on and check for voltage.Remember, run microwave as if you were cooking (Place water in unit when switched on).If there is power, then the motor is faulty.
Sep 25, 2009 | Bosch 500 HMB5050 Microwave Oven
Oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Bosch 500 HMB5050 Microwave Oven Logo
1,290 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
