Question about Pioneer Televison & Video
Pioneer monitor pdp 504cmx, 5 years old. working fine then lost picture and got red standby light that blinks, no picture. I have unplugged from power like the manual says but still nothing. When turning on, it goes from green light to red flashing in about 1 second.
  • 479 Answers
SOURCE: no picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
Posted on Dec 10, 2008
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
raklein62
  • 360 Answers
SOURCE: 5 rapid red blinks on the LED
Solution for error 1, 5 beeps,
For video data transmission from the Media Receiver to the PDP-434HD
and PDP-504HD-series Plasma Displays, digital signals are used.
Therefore, this unit adopts the HDCP (High-bandwidth Digital Content
Protection) system for copyright
protection. This unit is also provided with a detection switch (TRAP
switch) that will prohibit the unit from being turned on again "if the
upper plate of the unit is accidentally opened," in order to prevent
the panel technology from being leaked out.
The TRAP switch is disabled while the unit is turned off. When
performing internal diagnosis of the PDP, fix the switch to the OFF
position using adhesive tape before turning on the
unit. After servicing, be sure to remove the adhesive tape.
Well you've probably guessed what my next question is......How do i
unlock this receiver?. I'm told that it's simply a matter of keying in
3 buttons of the remote in a defined sequence. I have the service
manual but it doesn't say much about unlocking.
"The next generation of Blu Ray players will be equipped with
powerful explosives that will kill everybody in sight if the unit detects
possible tampering or if someone puts a DVD+R in it." )
( They use a photocell to kill the DVI board if light hits it
(as in the backboard removed). The TV continues to work, but not in
HD.
bypass the Pioneer's switch, or put black tape over the photocell.
Posted on Sep 30, 2009
SOURCE: 2 year old Pioneer PDP-5070PU plasma TV with red
While not aware of particular problems with this TV (others may know it better) based on the description and my practice with plasmas I'd be inclined to believe that one of the two sustain boards is near end of life.
Could also be problems with the power board, usually caused by dried out capacitors, but could not find reports of that through Google, so my first idea holds.
If you have a screwdriver, muscules to move it around and patience to unscrew all the bolts that hold the back panel you can actually test my theory by disconnecting each sustain in turn and seeing if the TV powers with no problems.
The sustains are the two large boards - one of each side of the display - left and right. Each sustain has a pretty fat power cable connecting it to either the power board or the other sustain (through which it may be getting power).
If I have to guess I'd bet on the Y sustain, which is the larger of the two, usually staying on the left side.
But that's just a guess - could be the other as well.
And, of course, could be just about anything else.
This is just best guess based on experience.
Bobby
http://www.coppelltvrepair.com
Posted on Jan 23, 2010
SOURCE: I turn on the unit the green light on the monitor
This is no time out for no signal it si power supply !!! You have too get new one !!!!! I had same problem with my tv!
Posted on Jun 24, 2010
2yr old Pioneer pdp-506 50" panel with seperate receiver unit
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
Jan 02, 2008 | Televison & Video
No picture. Monitor blinks 4 reds. Tv would come on for a few seconds then turn off. Now nothing but blinking lights. what do I do. Thanks
You have may be broke the system cable, the dvi-d cable is broke...
In my pdp-5030hd have the same problem, probe changing the only the dvi cable and works perfect...
The monitor blinks 3 red and the 4 blinks still in red...
Now i will try to put in the dvi-d input another source like a pc...
You need always the Pdp03u box for control...
Sep 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
Tv does not respond to turn on
the blinking light is to signify which break the error or short is happening it its used by tv repair men to diagnose the problems early on it will however require a technician
hope this helped
Robb
Apr 25, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Nov 18, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Loss of picture on Pioneer Plasma Tv
i have a pioneer 43 inch bought in 06. tv wont turn on light flashes red the light means standby. what does this mean
Jun 07, 2009 | Televison & Video
No picture on Pioneer plasma
Dec 10, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
52 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
