Question about Insignia IS-HTIB101 Theater System
DVD drawer will not open. Any ideas? System is a couple of years old but just out of box. DVD drawer will not open
    Genius:
  • 1,112 Answers
Hi:
Check the bottom of the DVD for a lock mechnasim, most manufactures lock the mechnasim in place for transport to vendors. Also check the user manual for more info on this procedure.
Posted on May 21, 2011
Why won't the drawer open?
Try this simple answer: on a couple of DVD players I've had, it takes several seconds for the drawer to open. If you press the Open button again during that time, it will close the drawer before it even opens. So try clicking Open once, and then leaving the player alone for a 20 seconds.
Oh, I should have asked first: is the power on? On some players, the power light may be on even if the player is off. Try pressing the power button and see if more lights come on.
Is there a chance that there is a foreign object wedged in there? In my experience, 3-4 years old is prime time for experimenting with DVD players. Have anyone that age in your house? If so, the safe but tedious way to fix that is to remove the case from the DVD player. That usually allows you to see the drawer inside the machine, to see if there's anything in there. The unsafe way involves prying the drawer out; it's unsafe because there is a good chance that you'll destroy the player, and an extremely good chance that you will leave unsightly marks on the front of your player.
Jul 31, 2015 | Televison & Video
Kenwood dv-5700 stuck drawer
If the player is still under warranty "one year standard warranty" return it asp, this is probably a manufacture defect.
May 09, 2012 | Kenwood DV-5700 Multi-disc DVD Player
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
My LG dv490h DVD player has its DVD drawer jammed open. When I press the button to close, it goes 20% of the way in and stops. My one year old pulled the drawer open this morning. Have taken the cover off...
The DVD tray has come off the alignment or settings which make it come OFF the mechanism. So you will need to push back the drawer back to the set position and this might be possible only after the loading mechanism is pulled out. The loading gear would have meshed with the loading drawer at mid way -due to the pull--and so it connecting only half way.
If mechanically minded you can remove the tray mechanism and reset the tray to the gear position in the DVD play/stop position.
Feb 04, 2011 | LG DVD 6053 DVD Player
DVD drawer does not open and the whole system doesn't work but it
defective unit, happened to me. i threw it out the window after fighting with it to get my dvd of american history x out of it, i then pulled my old dvd player out and resumed the movie. i recomend buying a new dvd player, or bust out that dvd player you got in the closet covered in dust
May 04, 2009 | Audio Players & Recorders
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
Dvd drawer
If this device is less than a year old, still under manufacturers warranty.
I do not think many technicians will like to fix these devices due to the high cost in labor and sometimes even for newer devices is hard to find service parts.
Try unplugging the DVD recorder and plug it back in after a couple of hours, hopefully that resets the memory; sometimes it works.
Apr 25, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Dvd drawer will not open
seems like the rubber band is broken. no there is not secret back door to it..you have to open it and change the rubber band. it is not that complicated
Mar 26, 2007 | Philips DVD750VR DVD Player/VCR
DVD Rom Drawer
This is a sure sign that the drive is faulty or the ide connection. Try a different ide connector from the other ide cable in your computer if you are able.
Feb 04, 2007 | HP Pavilion a1330n (EL466AA) PC Desktop
Insignia IS-HTIB101 Theater System Logo
91 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
