Question about Magic Chef MCWC16MCG Wine Cooler
Not cooling. Been turned off for days. Unplugged and plugged back in. Will hear a click every couple of minutes.
SOURCE: Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Feb 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
  • 82 Answers
SOURCE: MY magic chef CTB1922 IS NOT COOLING
Sounds like your compressor overload tripping. Compressor may be stuck from sitting. Start relay may be stuck from sitting. Try a new start relay after making sure all your wires and connections are good. Sometimes a wrap with a deadblow hammer on the side of the compressor can get it going. Don't pound on it just a light wrap. My guess is the relay or overload first. Unplug before fooling with any wiring!
Posted on Jun 28, 2009
erpaalai
  • 999 Answers
SOURCE: Mini Fridge not working MCBR445
Compressor is in a locked up/ no start condition. the overload cools enough to reset and tries to start it again and kicks out on amp draw, then the whole cycle starts over again.
Eric
Posted on Jul 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: stopped cooling
Best to unplug the refrigerator now and let compressor cool. The internal overload will be damaged if power remains on and trying to start. We need to test the compressor and start components before you buy anything, Let me know Sea Breeze
Posted on Aug 18, 2009
Compressor starts and then shuts off
I'm assuming it does not get cold.....did you turn the freezer when cleaning it? if so, you are supposed to let it [ the internal compressor oil ] drain right side up for at least 24hrs before turning on the unit.....try unplugging it for a cpl days, then plug it back it....if it still acts up, you may need to change a thermal coupling sensor......or depending on the age of the unit, replace it.
Apr 22, 2012 | Refrigerators
Our PFS22MISBWW fridge and freezer are the same temperature as my kitchen inside. Its around 4 years old. I've unplugged it, cleaned it out, vacuumed out the back bottom area, and waited 20 minutes...
Your nicely detailed and well worded question gives all the clues needed to suspect that the
compressor motor is effectively dead. What's happening is that the motor (correctly) receives input
from the control circuitry of the frig to turn on (to cool the interior of the frig) - it turns on, quickly
overheats (within a minute or two), and then the motor's thermal shutoff kills the overheating
motor (with a "click"). Then the motor cools for awhile, the thermal cutoff eventually resets
and allows current to the motor, which tries to run again, but quickly overheats again, etc.
May 30, 2011 | Refrigerators
Both sides not cooling. Hear a clicking noise every couple of minutes. Cleaned coils. Unplugged Start Relay from Compressor and plugged back in. Refrigerator still not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Amana ARS2661B Side by Side Refrigerator
Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
Jul 01, 2009 | Samsung LN32A330 32 in. LCD TV
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Freezer won't freeze
Sounds like you might have a bad relay on the compressor or the compresor is stuck and cycling on the overload... if you listen closly you should hear a low hum or buzz then a click... repeated ever 5-10 minutes tell overload cools and trys to restart again
Sep 02, 2007 | Frigidaire FRS23KF7AB Side by Side...
Magic Chef MCWC16MCG Wine Cooler Logo
70 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
