My pc wont install windows vista i get a blue screen. i did a hard disk test and it failed and it said missing data or corrupt..
    Scholar:
  • 106 Answers
It seems like your hard drive might have failed. Please check to see if the drive is recognized by the BIOS: Press DEL at startup and try to find the HDD into the menus, see if it displays correctly.
If it's not there, you can try plugging it to another computer, and see if it can be recognized, if all this fails.
You need to purchase a new hard drive.
Posted on May 21, 2011
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
How to fix blue screen of death on a dell latitude d610
The causes are bad device driver, virus, windows files have been corrupted, or the hard drive has failed. The only option is attempt a complete recovery of your operational sytem with a fresh install of windows, If this fails have the hardware checked for possible replacement.
May 12, 2012 | Dell Latitude D610 Notebook
Computer wont boot completely up missing or corrupt files
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 01, 2012 | Systemax Venture PC Desktop
Window 7 won't boot up
BECAUSE THE FIX IS LONG GO TO http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly
Apr 15, 2012 | Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
It won't turn on. It shows a black screen with "disk read error occured, press CTRL ALT DEL to restart. Then when you do this it does nothing.
Make sure you don't have any bootable CD/DVDs in it. Disconnect any external USB flash/thumb/hard drives.
If that does not work it is your primary hard drive. Either the data on it got corrupted, the drive is failing or has failed.
The first step is to try to repair Windows. Below is a decent tutorial but you can find more with a web search.
If Windows repair cannot find the hard drive the it has failed. You need to install a new hard drive and hope you have backup.
If Windows repair is buggy and gives you errors of missing data during and after the repair the disk is failing and "forgetting" data. Replace the disk.
Otherwise, repair will fix things so the only thing you need to do is scan for a virus or find the program that corrupted Windows.
Good Luck!
Aug 17, 2010 | Toshiba Computers & Internet
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
Read corrupted hard disks
one thing u should know first is that you cannot open the hard disk in another system if it is not the same system, because of the drivers and chip set. so to confirm this, u must test it from a system that is the same with yours.
Jul 17, 2009 | IBM ThinkPad T42 Notebook
OPS - windows Vista Business. Not able start windows Vista: 1. system restore - failed, error code 0x490 2. system files integrity - failed, error code 0x2 3. system volume on disk is corrupt.
You basically are having BSOD = Blue screens of death of the boot manager and causes your computer to crash and not log into the OS, I would recommend you do a DFT , Drive Fitness Test on the computer, you can download it from google and burn it to a cd and boot off of it and test your Hard Drive. Most likely you have a bad hard drive or bad sectors and these damaged sectors could have been system files that vista needs to boot into and since it can no longer access / find them you wont be able to log on. If you replace the Hard Drive and reinstall using your system Disks/ restore cd's you should be golden and up and running. If you dont have the disks you can call the computer manufacturer and they should be able to supply you a copy for a small charge. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 11, 2008 | Computers & Internet
4021WLMi blue screen
Is the message something like \Windows\system32\xxx missing or corrupt ? If so, you'll need to perform a repair: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314058
Dec 01, 2007 | Acer TravelMate 4021WLMI Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
