Question about Schumacher & Fast Charge Starter Charger
Power cord damaged to my schumacher SE-5212A battery charger, want to replace it but need wiring diagram.
  • 323 Answers
SOURCE: need manual
So to this site and download it.
http://manuals.batterychargers.com/manuals/00-00-000496.pdf
Posted on May 28, 2009
WonderTech
  • 268 Answers
SOURCE: need to charge 12v car battery
If battery is out of the vehicle, connect positive lead to positive terminal and negative lead to negative terminal.
If battery is in the vehicle, the proper way to connect leads depends on if it's a negative-grounded or a positive-grounded vehicle.
Here is a link to the manual for this charger.
Click where it says "Get This manual" (it's free).
Scroll down to pages 4 and 5 and it give detailed instructions on the proper way to connect leads and a lot more. It's a good manual to keep for future use.
I hope this helps.
http://powertool.manualsonline.com/manuals/mfg/schumacher/se520ma_se5212a_se1275a.html
Posted on Sep 22, 2009
SOURCE: schumacher se 4020
I would check Mcmaster Carr online and search for part # 7178K14. This is a pair of 200 amp clamps for around $8.00. I use this business all the time. They ship really really fast. Good luck
Posted on Apr 25, 2010
SOURCE: Issues with Schumacher Battery Charger SE-82-6 -
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
Posted on Mar 14, 2011
  • 6 Answers
SOURCE: Both Battery clips have come off of Schumacher
You need to connect the battery cable wires to the battery in order for the charger to "turn on" the output. If the "reverse polarity" LED lights up, switch the wires. The RED clamp goes to the + battery terminal wire, BLACK goes to the other.
Posted on Sep 22, 2013
Need wiring diagram or schematic
What do you need the diagram for? Is this a switch replacement? Turn off the power at the circuit breaker box and remove the cover plate to see the wiring or is this a new installation that needs to have wiring ran to it?
Aug 27, 2015 | Electrical Supplies
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
I need to see how the wires go inside a Schumacher SE-1052 battery charger.
Most likely that is not the case. Battery chargers that are not really old have current sensing and dont switch on unless there is a load attached to it. A totally dead battery wont be seen by the device and it wont charge it.
Jun 12, 2013 | Schumacher SE-1052 2/10/50 Battery Charger...
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
Looking for wirring diagram for schmacher SE-1275A battery charger. Wires got pulled out of component need to know where white wire & black wire goes.
yay I emailed schumacher asking about this and they got bak to me within 12 hours or so with EXACTLY what I needed
I looked a long, long time without finding anything like this online, and many different people asking the same questions
so please save this picture for your records, and if you have a minute, go post it on an unanswered schumacher battery charger wiring diagram question
Jan 18, 2011 | Schumacher DSR ProSeries Battery Charger -...
Issues with Schumacher Battery Charger SE-82-6 - Schumacher 3 Position Slide Switch (8 pins) - Does anyone know how the wires hook-up to to the pins on the back of the switch?
Nov 27, 2010 | Schumacher & Fast Charge Starter Charger
Schumacher & Fast Charge Starter Charger  Logo
110 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
