Question about Poulan Garden
I have a poulan pro hd6x self propelled lawn mower. i drov over something and the drive locked up. it no longer drives when i push the drive lever forward.
ken_howard
  • 10 Answers
SOURCE: starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Posted on Apr 25, 2009
  • 84 Answers
SOURCE: I have a Poulan Pro self propelled lawn mower. Was
i had the same problem. the coil is located under the "hood" if you may, just take that off and you should be able to get to it pretty easily,just unscrew the coil and find one on ebay for just about $29 for a 2-4 hp
Posted on Jun 24, 2009
  • 22 Answers
SOURCE: my poulan pro 6.75 self-propel mower stalls frequently
Replace the coil. Remove the top cover so that you can see the flywheel. There will be a horseshoe shaped peice with the plug wire attatched to it along with a small whir plugged onto it. Remove the two screws holding it on and unplug small wire and disconnect plug wire. When you put the new one on place a business card between coil and flywheel, this will give you the proper spacing, reconnect small wire and plug wire, reassemble top covers and you are good to go.
Posted on Aug 14, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
My front wheels stop turning I have to push it
Either the drive belt came off or something is jammed up in the wheel or drive housing and not letting it turn.
Jul 15, 2014 | Poulan Pro 22" Self Propelled High Wheel...
How to replace the self propelled
Make sure the cable to the transmission moves freely. If all the cables and lever s move freely than it more than likey is an internal gear needs replacing.
Poulan pro honda engine stalls as auto choke lever moves
it sounds to me that there s a jet inside the carb that is still plugged
Jun 24, 2012 | Poulan Pro " Pro" Self Propelled Mower
The engine of my Poulan Pro 600 is over reving.
Check carburetor/throttle to governor lever linkage.
Jun 12, 2010 | Poulan Pro " Pro" Self Propelled Mower
I need a diagram to assist in changing the drive
IF YOU WOULD POST A MODEL NUMBER FOR THE MACHINE THAT YOU WANT ADVICE FOR, IT WOULD SAVE A LOT OF TIME AND SOMEONE WOULD BE ABLE TO HELP YOU. IF WE HAVE NO IDEA WHAT YOU ARE WORKING ON, WE DON'T KNOW WHAT ADVICE/ASSISTANCE TO OFFER!!!
Sep 29, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
145 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
