Question about ASUS M2N-MX Motherboard
1. WHAT COLOR ARE THE ELECTRICAL POWER CONNECTORS ON AN ASUS MOTHER BOARD? White and/or black? 2. Can a small (short) pci card (USB 3) be inserted in a larger (black or white) slot? 3. My board has white and black pci card slots - which do I use for a small usb 3 pci card? Thanks much! JL
    Scholar:
  • 106 Answers
1. this is the manual for the board: http://support.asus.com/download.aspx?SLanguage=en&m=M2N-MX&p=1&s=24&os=22&hashedid=0pKBwEIE8tqMT4j7
it should be able to answer your questions.
Posted on May 21, 2011
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Diagram of xps 630i motherboard connections
xps 630i motherboard layout
1 - unused fan connector
2 - power button (POWER_BTN)
3- front LED
4 - front panel USB connector (FP_USB)
5 - floppy drive (DSKT)
6 - master I/O board USB connector (MIO_USB)
7 - front panel IEEE connector (FP_1394)
8 - reset button (RESET_BUTTON)
9 - RTC reset jumper (CLEAR_ CMOS)
10 - password jumper (CLEAR_PASSWORD)
11 - internal S/PDIF connector (internal SPDIF)
12 - front panel audio (FP_AUDIO)
13 - PCI card slot (SLOT5 and SLOT6)
14 - PCI-Express x16 card slot (SECONDARY GFX SLOT4)
15 - PCI-Express x8 card slot (SLOT3)
16 - PCI-Express x1 card slot (SLOT2)
NOTE: This slot is not available in the dual-graphics configuration
17 - PCI-Express x16 card slot (PRIMARY_GFX_SLOT1)
18 - power connector (12V_ATXP)
19 - processor (CPU)
20 - processor fan connector (FAN_CPU)
21 - black memory module connectors (DIMM2 and DIMM 3)
22 - white memory module connectors (DIMM0 and DIMM1)
23 - main power connector (POWER)
24 - IDE drive connector (IDE)
25 - North bridge fan connector
26 - SATA connectors (SATA0-3)
27 - battery socket (BATTERY)
Dec 06, 2011 | Computers & Internet
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
My card reader on my computer has stopped working!? ok i took my computer in to my computer teacher to get it fixed, well she put in a second hard drive in and said it should fine. well it does but...
Ah, My Bad, big_dude2010, perfectly understandable about the budget thing. The world is in an economic crisis right now.
As for reattaching the Card Reader cable, can't help you.
OH, I'm just PLAYIN'!
Before we go ANY further:
1) Computer off, and unplugged from power.
Unplug the power cable FROM the surge protector, and NOT plugged into the surge protector, and take it out of the back of the Power Supply.
With the power cable plugged into the surge protector, and unplugging it out of the Power Supply, you could create a voltage spike.
Result can burn out the Power Supply, and may go on to burn out the Processor, Motherboard, Ram Memory, and a graphics card. (IF used)
Many have stated, that they do this all the time. Eventually, they come back to state they fried out their power supply, and/or motherboard, and so on.
2) Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case to relieve your body of Static electricity.
Static can fry out, (Short Circuit), the delicate hardware components inside your computer.
(For this reason also work on a table. If you have a carpet floor, refrain from swinging your feet back, and forth.
If you get up, walk away, then return, TOUCH the metal frame again)
If you already know the above, please disregard.
The Card Reader cable has a white sheath, and is approximately as thick as a No.2 pencil.
It should have 8 wires in it.
Orange, Yellow, Blue, Brown, Red, White, Green, and Black.
It will have a white rectangular connector on one end, that has 10 socket holes. 2 rows of 5 holes.
Only 8 socket holes are used.
The other end of the cable should have a Black connector. It also has 10 socket holes. 2 rows of 5 holes. This connector plugs into the circuit board of the Card Reader.
The White connector end plugs into the motherboard. It plugs into the Front USB 1 header on the motherboard.
(Connector on a motherboard is referred to as a Header)
Orienting the motherboard, so we are both looking at it in the same direction.
Processor to the top. Ram Memory slots to the right.
There are 3 white PCI slots down towards the bottom.
The white PCI slot that is closest to the edge of the motherboard, is PCI3. (PCI 3)
Down below the PCI 3 slot is a blue header. NOT the one you want.
That's for the audio ports in the front of the computer. (Front Panel)
To the right of the blue header, is a white header. This is the one you want. Front USB1. (The Front USB1 header, is below the Right/Bottom corner of the PCI 3 slot)
Note that there are 5 pins going along the top of the Front USB 1 header, and 4 pins going along the bottom.
The missing pin, or blank spot, helps you to orient the white connector of the card reader cable.
The card reader cable's white connector also has a missing socket hole, or blank spot.
There is No slot on the header for the motherboard, and No locating lug on the Card Reader cable's, white connector.
Line the card reader cable connector's blank spot, up with the blank spot on the Front USB1 header.
This is HP Support, and the Motherboard Specifications page, for the Compaq Presario SR1303WM Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=447312
Scroll down the page about halfway, and you'll see an illustration of your motherboard.
(To enlarge it for better viewing, you can right-click right on it, then in the drop down menu, left-click on - Save As
Put this in your My Pictures folder.
Then go to My Pictures, and double-click on the illustration of the motherboard.
Now go below in the window, and click on the + sign to Zoom In.
Use the bottom, and side bar, to move it around to the view you want)
Below the illustration is an actual photograph of the motherboard, with no hardware components installed.
The Black connector that goes to the circuit board of the Card Reader, plugs in like this.
There are four wires across the top. There are five wires across the bottom.
Looking INSIDE your computer, TOWARDS the Card Reader circuit board, the four wires go on top, when plugged in. (Not shouting)
Again, looking at the back of the Card Reader, the color code of the wires on the top, going from Left to Right, are:
Thin Black wire, Green, White, and Red.
Wires going along the bottom, starting from Left going Right,
Thick Black wire, Brown, Blue, Yellow, and Orange
Feb 05, 2010 | HP Compaq Presario SR1303wm PC Desktop
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Front usb connections
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
Jun 11, 2008 | Packard Bell Computers & Internet
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
May 11, 2008 | ASUS P5PE-VM Motherboard
The usb cable are de-attached from the bord of my webcam
+Data
Green
-data
White
VCC
Red
GND
Black
BLACK BLUE BROWN are used as Ground
Apr 15, 2008 | Xirlink Promax Webcam
ASUS M2N-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
