Question about Samsung DV328AE Electric Dryer
Dryer has stopped drying, will not get hot, - Samsung DV328AE Electric Dryer
  • Samsung Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 26, 2011
MY DRYER WILL NOT DRY THE CLOTHES WHEN I USE THE REGULAR CYCLES. I HAVE TO DRY THE CLOTHES ON TIMED DRY FOR 90 MINUTES AND THEN SOMETIMES THEY ARE NOT COMPLETELY DRY. THE DRYER IS DEFINATELY GETTING HOT,...
Your vent system is more than likely stopped up..You may have to pull the dryer out and clean the flexible hose that connects the vent to the outdoors
Apr 12, 2011 | Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
My dyer will not dry the clothes
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
My Mag neptune dryer shows HP and stops drying
Hi again mssunnybunny,
I just thought of something,
You did not give a lot of details so pose this question just in case!
You only said, Your Mag Neptune dryer shows HP and stops drying!!!!!!!!!!!
1.Does it go but not get hot and not drying??
2.Or does your dryer not go and then make a loud humming sound like it's trying to go??.
If # 2 is the description and this was the case, then you need
a new motor!
Sep 13, 2008 | Maytag Dryers
Whirlpool electric dryer won't stop and won't get hot
The timer is in charge of stopping the machine. The timer seems to be broken.
Jul 23, 2008 | Dryers
Samsung DV328AE Electric Dryer Logo
188 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
