Question about Hotpoint 24 in. BF72 Built-in Dishwasher
Hotpoint BF72 integrated dishwasher - Had to force door open but did not damage it - Program shows 'P0', machine beeps twice as if it has just finished a program - all buttons dead except timer button which shows '22' when pressed - nothing else works - have switched it on and off and tried the test function thing where you press the 'P' button 4 times quickly - all to no avail
No solution, but mines doing the same..did you solve it?
Posted on Jul 26, 2011
My hotpoint diswasher is showing F as a fault in the door
can you send more information please like make model brand serial number
Sep 02, 2014 | Hotpoint 24 in. BF72 Built-in Dishwasher
Bf72 not doing the wash cycle correctly
If you are using hot water connection then check the temperature of incoming water is hot enough. If cold water inlet only is used then most likely the heater element or thermostat in the dishwasher is faulty and the water is not heating enough.
Nov 04, 2012 | Hotpoint 24 in. BF72 Built-in Dishwasher
Dishwasher
It could be you opened the door before it had fully completed a program, and then turned it off. My Hotpoint machine has to be reset in these circumstances otherwise the next time it is turned on, it appears to let you select a different program but when you close the door resumes the program it was running when it was interrupted.
You don't say which model you have, so I cant give you a definitive answer, but you could try the following sequence which works on my Hotpoint:
1. Open door and switch machine on.2. Press and hold down the P button for several seconds until it gives a series of beeps (mine = 3 beeps).3. Release P button.4. Select the program you want in the usual way using the P button.5. Close door, and the machine should then run the selected program.
Hope this helps.
Sep 18, 2012 | Hotpoint Dishwashers
Program button will not move from "P0". What can I
Press Accept or replay
I have a solution for this
Bruce
Jan 14, 2011 | Hotpoint 24 in. BF72 Built-in Dishwasher
The door lock on BF72 integrated dishwasher will not release
the best way is to try and break in, use flat screwdriver push it in the uper area from the handle part (right above) and try to pull the hole mechanisam down, this will cose miner damage to your door but it wont'e be visivle
Oct 30, 2009 | Hotpoint 24 in. BF72 Built-in Dishwasher
New Integral Hotpoint dishwasher LFT04
We finally worked out what all the separate parts were for!! The instructions given were hopeless! Would be pleased to help anyone who encounters the same problem.
Dec 26, 2008 | Hotpoint 24 in. BF72 Built-in Dishwasher
Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Sep 27, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint 24 in. BF72 Built-in Dishwasher Logo
148 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
