Question about Refrigerators
Fridge wont cool - Refrigerators
  • 88 Answers
Chack gas (cylender)
Posted on Aug 15, 2008
Why wont my fridge cool?
Hy Tony,
Compressor is a pump and operates by a motor. Cooling is initiated by the coolant. If your fridge runs low in the coolant, it won't give you a satisfactory result. Have a qualified technician check and if need be, refill the appropriate coolant.
Oct 12, 2014 | Refrigerators
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
Fridge wont keep cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | Refrigerators
I HAVE A SAMSUNG HALF AND HALF FRIDGE FREEZER MODEL NUMBER RL36EBSW THE PROBLEM IS THE FRIDGE WONT GET COLD
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Refrigerators
The fridge is running and the freezer is keeping cold but the fridge part wont stay cold?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working fine, fridge is 65 degrees and wont cool down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Amana Refrigerators
The freezer is 10 below but the fridge wont cool lower than 52 degrees
heatman101
Sep 08, 2010 | GE Refrigerators
Thetford fridge wont work on mains power
start by putting the fridge in a cold place or if that don't work then turn the temp down inside the fridge
Dec 19, 2009 | Thetford Porta Potti
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
May 10, 2009 | Refrigerators
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
