Question about LG WFT1071TP Top Load Washer
Lg topload washer lid is locked and it wont come on
Lg washer wm2455hw door won't lock. DE code flashes.
LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Nov 15, 2015 | LG Washing Machines
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
De error but the machine have not door switch
if its front loader door swich is there,,but toploader no door swich but with main pcb having sensor,,locking with door lid with megnet,,,
Feb 08, 2014 | LG Washing Machines
The load finished on my whirlpool cabrio washer (topload) but the machine won't unlock the lid?
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
May 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
MY fridgadaire lg washer says loc and wont start
It is the Lid lock, that is what loc means. It is integrated with the lid switch. Part needs to be replaced. Look up model number and go to appliance parts store or website. If at website print blow up of unit to see where switch is located. UNPLUG unit first.
Aug 26, 2009 | LG WM2688H Front Load Washer
LG toploader washing machine alarm signal Lid Open.
The lid switch is bad, not making contact.Replace switch or see where it is not being contacted by the lid or hindges when the lid is closed.
Jan 04, 2009 | LG KU990 Viewty
LG WFT1071TP Top Load Washer Logo
185 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
