Epson Printer Fix
Thank you so much.  I was messing with my printer for almost 45 minutes using the Epson website and their diagnostic tools before I got the idea to google "epson cx8400 blank pages" And your answer was #1 on google -- after just posting it yesterday.  Your answer had me fixed up in two minutes, and now I'm printing like a champ!  Thanks so much for saving me further frustration and time wasting.  I'm super grateful to you.
Respectfully yours, Silver Persinger
PS. I'm running for US President as a write in candidate.  www.votesilver.org
Inky
  • 691 Answers
SOURCE: Epson C88 printer only prints blank pages
See my post about about underhead cleaning. If that makes no difference you will need the countermeasure for the split cap tube. The document about loss of ink on CX series machines is also applicable to C88
Posted on Jul 18, 2008
SOURCE: Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
Posted on Aug 13, 2008
  • 11 Answers
SOURCE: Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Posted on Jul 07, 2009
SOURCE: Cannot Print from on Epson CX8400 from Mac OS X Leopard
I could only get my CX8400 to work with Leopard once I manually selected the driver located at /Library/Printers/PPDs/Contents/Resources/EPSON Stylus CX8400.gz
I think that may have appeared after installing a driver downloaded off the web, but I didn't track my steps carefully enough to be certain. I used http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
I know this is a bit jumbled, but hopefully it helps.
Posted on Jul 22, 2009
YourZEN
  • 820 Answers
SOURCE: Epson Stylus CX8400, Printer, Copier, Scanner. Need manual.
Manual for Epson Stylus CX8400:
Quick reference guide in pdf-format can be downloaded here:
http://files.support.epson.com/pdf/cx84__/cx84__qr.pdf
An overview of all documents and manuals on this site:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=90342&prodoid=63069506&category=Products
Posted on Aug 20, 2009
I can not use the printer because "a scanner
run the printer diagnostics utility from epson that came with the printer they should indicate whether this is a setting error or a serious malfunction with the printer - multifunction devices are interdependent on the different parts to make themselves work You have already tried pulling the plug on the unit for 1 minute then plugging back in to reset the device? try the reset first then the diagnostic...
Oct 24, 2013 | Epson Stylus Multifunction Inkjet Printer/...
I used printer Epson B510DN. My printer having a problem: printer error / restart printer
If you are not a proficient Epson Printer user, you can take a online support from Epson Printer Support Number (+1-888-840-8298), USA's technician will help you out via online remote access tool and fix the existing issue at the same time.
https://www.supporthelpline.us/epson-support-phone-number
Oct 16, 2013 | Epson B500DN InkJet Printer
Espon printer's ink pads are at the end, how do i reset or fix it? thank you
Try unplugging the printer for a few minutes. Then plug it back in. When it runs through the initial set up it should reset.
Jan 18, 2013 | Epson Artisan 800 All-In-One InkJet...
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
Can't delete document. printer won't print
Find and Fix Common Printer Problems Using HP Diagnostic Tools Review the following sections to learn about the diagnostic tools that HP offers, and then follow the links to learn how to download and install the tools. You can also use the following shortcuts to go to the section in this document that is related to your issue: HP Network Diagnostic Utility HP Print Diagnostic Utility HP Scan Diagnostic Utility HP Network Diagnostic Utility Network connectivity and communication is everything when it comes to networking your HP printer. The Network Diagnostic Utility provides help and information that is necessary to resolve network issues, including:
  • Verifies network and wireless connection status for your computer and the HP printer
  • Identifies security type and security key for your network
  • Identifies firewalls and supplies related help
Learn more!
Using the HP Network Diagnostic Utility (c02037530) (in English)
Oct 27, 2010 | HP Deskjet 3845 InkJet Printer
Parts inside your printer are near the end of their service life
Hi and welcome to FixYa,
A possible workaround to "end of life" on Epson printers; download, install and run "SSC Service Utility"
Good luck and thank you for asking FixYa.
Aug 13, 2009 | Epson Stylus Photo R220 InkJet Printer
My epson stylus c 45 does not operate both red and green keeps on blinking
Almost always, your describe concerns and considering the age of the unit indicates that the Epson printer has reached its " end of life " (most likely) or there is an internal fault (least likely). Initially, I would suggest to download and install ' SSC Service Utility for Epson Stylus Printers '. Its purpose is to bypass the counters and reset most Epson printers. The reset would force the printer to revert to factory defaults. The printer would be " fooled " into thinking that it is new (again).
Good luck and thank you for using FixYa.
Jun 25, 2009 | Epson Stylus C46 InkJet Printer
EPSON PRINTER NEED SERVICE
your printer wast pad is full so the printer need to be reset if you dont have the tool let me no
Nov 02, 2008 | Epson Stylus C46 InkJet Printer
Printer-adjusting alignment
hi terra
just try by reinstalling the drivers for the printer
May 21, 2008 | Epson Stylus 880 InkJet Color Printer
My epson stylus printer c43sx
Yes. It is time to clean all the mess, including all pads and mechanism.
Mar 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
48 people viewed this question
jasbo
jasbo
