Question about GE GTS22KBP Top Freezer Refrigerator
My GE TBX22Z runs about 22 hr/day. I have coolness controls set in middle. Freezer is 15 below and fridge is 38-39 degrees. The unit is 23 years old. Should I get a new model?
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 22, 2011
Just had the thermistors replaced in the frigde freezer the fan is working now and the freezer is - 22 but the fridge is at 14 degrees.
Where are you getting these temps from? If your unit is in Celsius mode, that would mean fridge is 57.2 degrees and Freezer would be -7.6 degrees. Without a model number I am unable to see the style of controls you have. Double check all settings are in the middle, meaning if you have a digital display, temp @ 0-36, if you have dials make sure they are set to the middle ie..(a-e then set at c, 1-9 set at 5).
I hope this helps...
Jul 23, 2011 | Refrigerators
I have a GE Profile PSW26PSW. I bought it new in
If the condensor is dirty, the frig will have to work like the dickens to to stay cool. The condensor coils are either under the unit, or on the back. the newer units tuck them neately under the unit and a good toilet brush, degreasser soap, like "Dawn" works great. If she still is heading south, My first guess would be the compressor, or the thermostat. Try the Condenser coil cleaning first. Lloyd
Jun 01, 2010 | Refrigerators
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer on refrigerator continually runs. GE refrigerator is 20 yrs old. The refrigerator part cools fine. The top freezer is continually running, is also freezing well. Is this a sign that the freezer is...
well, if its 20 years old, and still cooling NORMAL in both the freezer and fresh food, with the controls at normal middle settings. then no, you dont need repairs. if temps are a little warmer, or even a little colder than normal, or in order to keep it at a normal temperature, you have to adjust the controls to a colder setting, then you might need a repair.
if it is cooling ok, and running more, the tradeoff of running longer, is its drawing less power than it used to when it ran "normally" so the trade off is about equal. factors that can make it run longer, is it near a heat source, is it sitting in the sun most of the day, is there not much food inside, is it being opened frequently, is it near the stove, are the doors sealing good, all four sides of both should be contacting the face of the fridge, are there any tears, rips or gaps in the door seals, i could go on.
Jan 22, 2010 | GE J Series 20.6 cu. ft. Top Freezer...
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Freezer warnm up
It does sound like the normal defrost cycle. Aslong as it stays at an average below 12 degrees it is normally working fine. Check to make sure the back air vents and front grille are clean and the fan by the compressor is running when the unit is on. It has to get rid of the heat so it will freeze.
May 16, 2008 | GE GBS18KBM Bottom Freezer Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
177 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
