Question about Philips 60P8341 60" Rear Projection Television
Philips 50p8342 problem
Hello i have a philips tv 50p8342 the tv will turn on and stay on for a hour then it will turn off also when the tv is on the power button will not turn it off but the remote will turn the tv off.The TV blinks twice fast then it will stop then blinks twice again.
  • peachy255 Dec 02, 2008
    I have the same problem with a 32" Phillips CRT tv. Any information on how to fix this would be helpful!
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Posted on Oct 06, 2008
Our philips lcd tv picture turns off but sound stays on and then the piture won't come back on for longer while.
Suddenly, the sound for LCD 42PFL3605/12 dissapeared. Resetted to factory settings, upgraded firmware, but no result. The TV ran just 24 hours. Please, help!
Dec 19, 2010 | Philips 47PFL7403D 47 in. LCD TV
I have a Philips 50p8342 television. When it is
Sounds like you are tripping your crowbar circuit. This is most commonly caused by one of the Red Green or Blue brightness adjustments, adjusted too high. The crowbar circuit protects your high voltage guns from getting damaged. I know this because I just did this myself. My adjustments were behind the lower rear panel in a small box screwed to the chassis. There are 6 tuning pots on mine. 3 for focus of the RGB and 3 for brightness of the RGB. The focus ones didn't seem to have any effect on the crowbar circuit. However, by turning the brightness down on each of the RGB pots I could get the T.V. to stay on indefinately.
Oct 18, 2009 | Philips 60P8341 60" Rear Projection...
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Bad power supply P/N 313503710471
$495 to repair is good.
The original replacement is $469.75 : 313503710471
Refurbished part is $228.83 : 313503710471
Nov 13, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8342
PTS 18008447871 can repair the board and give a price
Dec 13, 2007 | Philips 50P8341 50" Rear Projection...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
I have a 50P8342 with simular problem
My tv was doing some of the same type things I touch one of the manual buttons ont tv and the channel would change or the volume would go up or down. I changed the control board behind the manual buttons on the face of the tv and now it works fine with or without the remote. the part no. is 313501707611 go to sears web site type in this number and order it. this part will come up as 60P8342 but thats ok becouse the 50P8342 and the 60P8342 use the same part number I know I have both models and changed them both using the same part and part number.
Nov 19, 2006 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
400 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
