We have just received our new Beko Wmi71641 and during it's first run we had to press the cancellation button (held down "start/pause/cancel" for 3 seconds). The "play/pause" icon is now flashing and the washing isn't doing anything. We have tried powering it down with no luck. The manual says the only way to cancel a wash is to hold start/pause/cancel for 3 seconds. We've tried this and also tried unplugging it from the main for 5 minutes etc. Any ideas?
  • 156 Answers
SOURCE: Kenmore Elite HE3 washing machine model 110.45862404
ck pump door lock
Posted on Feb 28, 2008
SOURCE: Duet Whirlpool Washer
You need to go to the right, to the end of cycle signal volume control button. Push it and hold it until the beep and it will go off. This is the "child safety" feature so that little ones won't interrupt your wash when they push the buttons. (and they will)
Michell~
Posted on Jul 11, 2008
jsrock516
  • 5911 Answers
SOURCE: ''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Posted on Nov 14, 2008
  • 111 Answers
SOURCE: Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Posted on Jun 18, 2009
  • 82 Answers
SOURCE: The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Posted on Jun 28, 2009
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
WMB 71642 W won't allow programm set
have you held the start button for ten seconds to cancel the program
Feb 03, 2014 | Washing Machines
How do i reset my toshiba satellite L305-S5955 to factory default & erase all data from it?
Close out any software currently running on your Toshiba Satellite L305 laptop.
Navigate to the laptop's "Start" menu and choose "Shut Down."
Hold down the laptop's "0" key and press the power button.
Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again.
Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
Use the prompts that appear on the screen to choose your region, time zone and keyboard settings.
Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
hope this helps
Sep 06, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Beko DRCS68W not entering reset mode
If there is voltage on the thermostat but not going through even when the temperature is down it is possible that this could be defective. Now check using a multimeter to confirm the continuity on the thermostat and if the reset switch on this - if present - is off, if so press it down.
Now confirm the voltage from the control panel during the heating cycle and if voltage is outputted then it must flow. The connection must be checked on the heating element- trace to confirm.
Jun 27, 2012 | Beko Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Indesit1200 front loader not filling and flashing error code deno can anyone help
hi try these
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Aug 22, 2008 | Indesit Washing Machines
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Leave power on.
Apr 26, 2008 | Washing Machines
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
