Question about Yamaha Boating
15hp 4stroke will start but runs on one plug - bouth good spark -bouth plugs are black with asooty deposate after being started and run for a minite-carb mixture? 15hp 4stroke yamaha outboard motor every time you start it ive had three mates have a go at setting carb mixture
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Yamaha Master
  • 1,190 Answers
Compressions ok ? 100psi min !
Posted on Jun 10, 2014
3 Suggested Answers
  • 8 Answers
SOURCE: My 2 stroke 3 cylinder carbureted 90 hp Yamaha
Just pull them apart and clean.
Posted on Nov 07, 2010
goldbill
  • 184 Answers
SOURCE: tohatsu outboard 15hp 2 stroke was running great,
First: with flashlight or mirror look down the carb- with switch off- and gear and throttle wide open and see what the butterfly valve inside there is doing. It should be parallel to the air flow.
If not you need to find the actuator am and be sure it moves with the control and opens all the way.
Next make sure the timing plate under the flywheel moves at the same time the throttle is opened. Then -using timing light- see if the timing is set to the correct "wide Open throttle" - this is a 2 man job done at sunset with good marks on the flywheel (don't wear a tie). This can also be done static by running it out of gas and using the pull cord- if it has no safety interlock.
Last- and the saddest part- is the compression test. The strength of the reading is not as important as the similarity. When I worked on Chryslers, they were bad if the two readings were as little as 8# apart. The minimum reading should be over 80#.
Posted on May 26, 2011
Can't start Gardeners choice 4stroke doesn't seem to have any spark even with new plug
Check for a spark leak. Look for a spark anywhere the spark plug wire goes near metal. A mistake of water might help.
Jan 29, 2017 | Garden
4stroke 9.9 Suzuki starts hard and only runs with choke out ,only idles,sputters when I give it more gas
Have you checked air filter? If Ok it will be a blockage in the carburetor try the main jet first.
Sep 21, 2014 | Motorcycles
What is causing the spark plug to foul out with black carbon
check for oil gas mixture or its bad rings
Jul 02, 2014 | Garden
Spark plug come all black like if is not burning the gas right what could it be
Air/Fuel mixture is not accurate...could be small like the Idle Air Control valve...but could also be fuel pressure regulator...more costly and a little more work. Hope this helps.
Apr 13, 2012 | Chrysler Cars & Trucks
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
Ryobi 4stroke brush cutter, fading on full throttle
This running pattern often indicates a lean fuel mix.
Unfortunately, with today's environmental hysteria, you probably will not be able to adjust the carburetor enough to get it to run better. If you do have any carburetor adjustment available, try turning the screw (the high speed screw, if there are two) counter-clockwise a bit. This will allow more gas into the mixture. Most small engines today have limiter caps that prevent very much carburetor adjustment.
Oct 10, 2009 | Garden
I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Jul 10, 2009 | Garden
Got a loncin explorer 90cc quad had trouble with starting it, since i bought it from new. took it back got a new battery and starter fitted at cost was fine for a week or so, but now wont start again, its...
ive bought 1 and had the same problem , change the spark plug for an ngk , and use shell v-power petrol ( or any other high octane fuel ) myn now starts first time every time :) and go's like stink also consider buying a better battery , the standard 1's are **** !
Mar 16, 2009 | Cycling
Boating Logo
103 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
