Question about Cycling
I have an EDGE 490 Programmable Bike. I purchased it used, I think it is an older model. Lately the display board doesn't seem to work all the time. It starts by rotating the pedals. Sometime ago it did this and started working again. I moved the bike to vacum the floor and it now doesn't want to seem to work at all. Any suggestions on what I may do to correct this. Thank you for your time.
  • 8 Answers
SOURCE: Wont start
FIRST thing to check is spark plug ,make sure it is sparking ,if it is and is wet change the plug .If plug is dry it could be the carb needs cleaning out if it has beesn stood for a while
Posted on Nov 16, 2008
SOURCE: Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
This is where I am getting the AC parts for my 201.
Posted on Mar 22, 2009
  • 34 Answers
SOURCE: Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
Posted on Apr 07, 2009
  • 1138 Answers
SOURCE: How do I get a replacement for a Disney Cars Huffy bike pedal?
You probably can't obtain an original part but if you can get the pedal off the crank ( right pedal unscrews counterclockwise, left pedal unscrews clockwise) you can take it to a good bike shop to match it up to a new one. You will probably have to buy a set unless they have a spare in the shop. Hope this helps.
Posted on May 26, 2009
SOURCE: Life fitness recumbent bike problem
We had exactly the same thing. If you take the covers off you will find a black battery pack in the bottom. It is about the same size as a cordless drill battery. We got a replacement from Maplins - cost about £10. It works perfectly now.
Posted on Jun 17, 2009
How to make the clock/drip coffee maker work. The display does not turn on anymore.
DeLonghi BCO120T Programmable Espresso Coffee Maker Team says:
1. Your coffee maker PC board/display might get fused or blown off. You just need to replace the PC board.
You can claim the warranty if recently purchased through If you are in India then contact us at
Nov 03, 2014 | DeLonghi BCO120T Programmable Espresso /...
I need the codes for an older ge universal remote control. you able to help me out?
You have this backwards. The codes are stored in the remote. I think you want to use an older model GE programmable remote to control some unidentified device. Use the programming (code search) feature to find a code that works. If nothng is found, you may have to try another programmable remote. Not all remotes store the same codes in their libraries.
Sep 13, 2014 | General Electric Universal Remote Control
Two different replacement LCD mainboards don't work
There are several versions of main boards for most models and all appear identical in everyway. But there are slight differences in critical areas. Chances are your not getting the correct version board. If you let me know the model number of the set I can most likely cross reference which version you have by the numbers off your original main board.
Oct 15, 2012 | Viore Televison & Video
Frigidaire dishwasher stuck on wash cycle, doesn't complete - model # FDB1050reb0
This model doesn't use a timer like older types, The element is turned on and off by the electronics and a failed board can cause the symptoms mentioned, thee is no real way to test the board as the integrated electronics are quite complicated. The board is easy to replace, if you can use basic tools you would be able to manage it.
The dishwasher is cold fills so heats it's own water so the hot water temperature in the house has no impact on the dishwasher.
Mar 10, 2012 | Dishwashers
Ok i got this exercise bike at a yard sale its the stamina R360's and I didn't notice it doesn't contain the petal straps for it i need them for pt at home, tkr so my foot doesn't slide off...
Fixya does not sell replacement pedal straps and would not know of sources.
For a manual, try Googling (stamina)(R360s)(manual) without parens.
Aug 10, 2017 | Cycling
My "Edge 491r" recumbant bike
Same as above, have an Edge 491 with E1 and need to fix it
Jan 04, 2011 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Husqvarna 1+ programmable card
To the second poster with the malfunctioning "card" - do you mean the insert panel/card (overlay) with "E" on it? If so then there is no programmable feature to it. The overlay has notches in the left edge that presses a pattern of leaf switches on the left behind the case and it uses internal designs in memory. If on the other hand you mean that little memory card that you can use with the reader/writer and goes with the "0" (zero) card/overlay then you can get them from a Husq-Viking dealer, or keep an eye on used ones on ebay.
Most dealers sell the "programmable" as a "0" (zero) card set where you get the zero cassette/panel/overlay and the little programmable embroidery card as a set. Most reader-writer sets, either the older parallel port type or the newer 3D/4D USB one will come with one many times. You need to check the dealers and see what they have to offer. The programmable embroidery card is still rather pricey. I'm looking into whether there is some generic type memory card that might work too but have yet to find one and may not since the HV programmable card is likely proprietary since it goes back to the early 90's.
Mar 13, 2008 | Husqvarna Viking 1
Cycling Logo
484 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
