Question about Kenmore HE2 Plus Front Load Washer
When tub spins it sounds like it is hitting metal. I have leveled it by putting plywood under it. How do you access the front? I've looked in the back and it seems to be okay.
  • Kenmore Master
  • 8,220 Answers
You remove the service panel.
Service manual for Duet Sport and more HERE
Posted on May 21, 2011
Tub is uneven.
it would appear as the drum bearing has collapsed,the rear panel will need to be removed to gain access to it.
Nov 13, 2012 | Washing Machines
Can the hand-held shower hose be replace without accessing the plumbing underneath the tub? I can't figure out how to disconnect the existing hose from the diverter without cutting an opening under the...
No, you need to cut a hole. Usually an access panel is provided during the initial installation, either in the ceiling from downstairs or in the other side of the adjacent wall. But it's pretty easy to add one. After you cut a nice rectangular hole, you can cover it with a piece of painted plywood that has a trim piece attached to the plywood. The plywood is held in place with a couple of screws. When you remove the panel, the trim stays attached to the plywood. When you place the panel in the hole, the trim covers the gap between the drywall and the plywood.
Dec 01, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Washer FTR630ASO Fridgedaire - inside tub is loose and loud
we've got this exact washer. we had a very similar sound/problem. it turn out to be the shock absorbers. easy replacement. under $100.
Oct 08, 2009 | Washing Machines
What do you advise I put under my washer and dryer? I need to slide them out service but I don't want the leveling legs to scratch the tile floor which is limestone and scratches easily.
I put a piece of 1/4" plywood in front of the legs, stand on the plywood and lift the front legs onto the wood. Slide the machine forward until the back legs hit the wood and tip it up on the back and on to the wood. Cart it away from there if that is necessary.
Sep 15, 2009 | Fisher and Paykel GWL11 Top Load Washer
Violent shaking on spin cycle
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
When on spin cycle, Maytag MAV5057AWW vibrates excessively more so than just an unbalanced load. When I open the lid the whole tub and agitator is moving around alot forward and back as well as side to...
Aug 16, 2009 | Maytag MMV4205 Microwave Oven
In the final rinse spin my washer makes a horrible sound like metal hitting metal. It does this with all washes. Could it be permanently off balance?
Hi, check leveling of washer, with spirit level, after leveling, put both hands on washer, and try to rock it, side to side, front to back, there shouldn't be any play, (movements) it's possible that you have a broken spring, you will have to open washer to check, can you? if not let mechanic check. good luck.
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
