Question about CORSAIR Builder CX500 (CMPSU500CX) 500-Watt Power Supply
First boot up works fine, then 5 minutes later.. the pc turns off instantly (no blue screen) reboots for about 5 seconds then turns off again, then boots up for half a second then doesn't reboot at all. I would have to turn the psu switch off, wait an hour then and on again, then the whole process is repeated. I have had the pc for 2 months and it worked fine up until 1 week ago when it failed. i don't believe the psu is faulty because it shouldn't of worked from day 1 if it was. I believe the psu is more than sufficient for the system because it was designed like that by the company, whom i bought it from. intel quad core i5, overclocked 4500k radeon HD 6850 cyclone, 2 usb devices, 3 fans including cpu, 1 dvd drive, 1 hard drive. 2 x 4gb(2x2) mushkin enhanced ddr3.
  • rob_asquith May 21, 2011
    I tried every connection inside the pc, removed and re-inserted every power cable. still no change
    I also tried an experiment, i completely removed the psu from my new pc and crudely rigged it up to power my old pc (which requires a lot less power because it has a 350w supply). the psu re-acted the same way to my old pc, just took longer to cut out, about 30 minutes.
    the psu fan works fine..
    how do i test for faulty leads?
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 21, 2011
  • Brian Sullivan
    Brian Sullivan May 21, 2011
    is the hard drive IDE or SATA if its IDE replace the 40 pin flat IDE lead this is usually the first to fail even something as small as an electrical extension or a faulty fan lead can cause this problem make sure the connections are good and dust free a computer must continue its cycle and have an end to function which means the imformation must travel through all of your devices and finally finish follow this troubleshooting procedure
    hope this helps
My tecra A6-ez6311 won't boot up when 'hot'.
I am pretty sure you have a root kit virus. Some would try to fix this, and some to be certain will wipe the disk and start over.
I try to hunt out the problem. Every computer that acts like this that I have seen have been Toshiba's with 512 to 1megmb of memory. They do have issues with the power plug being lose which is attached to the battery charge, so do not rule that out. Heat and time are what it could also be. You may have both a virus and power issue. it happens but not often. If it is virus only, I can fix this remotely with my services for $180 money back. I can tell in the fist hour if I can get it. Might not be worth it.
e
Nov 20, 2011 | Toshiba Tecra A6-EZ6311 Notebook
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Startup is normal, then while working for about 5 minutes, it freezes. reboot and it does the same thing again.
here is something that might do the trick, Compaq use a quirky set of motherboards, and they akk seem to have this problem sooner or later
1) unplug everything from the computer except for the keyboard, mouse, and screen
2) unplug the power cord
3) wait 30 seconds, then hold in the power button for another 15 seconds
4) plug computer back in and reboot system
if it works then you're good to go.
if not, then there is a resource conflict which is sendinga fault code to the OS, causing a reboot
if you recently installed any hardware, ur USB adapters, that could be the cause
also, sometimes does this if print and file sharing is turned on
Dec 16, 2010 | HP Compaq nc6220 Notebook
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
After a hard reboot, my HTC G1 works fine, then locks up about 5 minutes later. I've tried both soft and hard rebooting. What's the next step?
Factory restoring is the next step. To do this, when booting the phone, you will need to hold the home button and power button as the phone is booting. Keep holding these even while the G1 screen is displayed. After about 30 seconds, the screen will change to a triangle. On the triangle screen, you will then wait approx. 5-10 seconds and then press the home and power buttons one more time. This will bring up an options menu that will let you wipe and restore your phone settings. As long as you have your gmail information in the phone, you will not lose your contacts.
Apr 10, 2010 | HTC G1
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
My F11 key wont work it wont go to recover system. I been having problems with my ip address
To use PC Restore:
1. Turn on the Computer. During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2. Immediately upon seeing the blue bar, press <Ctrl><F11>. If you do not press <Ctrl><F11> in time, let the Computer finish restarting, and then restart the Computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3. On the next screen that appears, click Restore.
4. On the next screen, click Confirm. The restore process takes approximately 6–10 minutes to complete.
5. When prompted, click Finish to reboot the Computer.
NOTE: Do not manually shut down the Computer. Click Finish and let the Computer completely reboot.
6. When prompted, click Yes.
The Computer restarts. Because the Computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the Computer was turned on.
7. Click Next. The System Restore screen appears and the Computer restarts.
8. After the Computer restarts, click OK.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Dell Computers & Internet
My advent 7108 had the blue screen followed by the white screen
it is Hard disk problem. pls replaced it & installed os again.
Aug 21, 2009 | Acer Aspire 4720 Notebook
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
CORSAIR Builder CX500 (CMPSU500CX) 500-Watt Power Supply Logo
158 people viewed this question
Top CORSAIR Computers & Internet Experts
Ezewudo Onyekachi
Ezewudo Onyekachi
JonSnell Electronic
JonSnell Electronic
Alex Cries A Lot
Alex Cries A Lot
Level 1 Expert
Are you a CORSAIR Computer and Internet Expert? Answer questions, earn points and help others
