Question about TechFuel® 6 Cell, Battery (SATUMT577) for Toshiba PA3817U-1BAS Laptop
My notebook stopped charging the battery, I tryed other batteries but the problem is on the notebook. It works as the battery is being charge but the charge meter does not goes up only goes down when running on battery. I am trying to find the pin signal assignment for this battery and will be very glad if you can inform it. Francisco
  • 8 more comments
  • paco64 May 21, 2011
    I already tried 2 new batteries and the same thing happened. The notebook works without the battery. Is it possible to have a pin assignment for the battery connector. I saw that some batteries have a solid state switch that is controlled by the computer.
  • paco64 May 23, 2011
    The laptop is a new one bought 2 months ago at Bestbuy, there is no corrosion on the connector.
    There is no corrosion on the connector. The laptop is a new one bought 2 months ago.
  • paco64 May 24, 2011
    There is no corrosion on the connector. It´s a new laptop bought 2 months ago.
  • paco64 May 25, 2011
    My friend, the contacts on the laptop are male exposed contacts, are not corroded and in perfect conditions. If there is a contact problem it should be on the battery connector but I´ve tried 2 more batteries.
  • paco64 May 26, 2011
    The battery terminals are solid male blades, which are perfect and also with no corrosion. If there is a contact problem it should be on the connector at the battery which is a female connector and more fragile. But this problem happened with the original battery and 2 new ones that I tested.
    The battery contacts on the laptop are male blade contacts, they are in perfect condition and without any corrosion. A contact problem would be more probably on the battery connector that is a more fragile one but I tried 2 more batteries and all with the same problem.
    The battery connector is a male blade type connector. It´s in perfect condition as the blades are exposed and can be examinated easily. There is no damage or corrosion. The battery conector which is a female is more fragile but I´ve tested 2 other batteries and the results were the same.
  • paco64 May 30, 2011
    Yes, the system power on without battery.
  • paco64 Jun 09, 2011
    Yes, it powers on.
    Genius:
  • 1,196 Answers
The problem is with the battery, the battery is been shorted, perhaps, due to power surge, the problem is not with the charger, to confirm this, if you remove the battery and plug in the charger to your notebook, you will see that it will still work, all you need do now is to get a replacement battery, because there is nothing you can do other than getting a new battery. Once you fix the battery, the problem is fix.
Posted on May 21, 2011
  • 1 more comment
  • Ishola Olayemi May 21, 2011
    I think the battery connectors on you laptop is corrode and will need to be replace, you will need to change the battery connectors on your laptop because they are not making contact with the battery that is why it is not charging. Once the battery connectors are changed, the battery will charge.
  • Ishola Olayemi May 24, 2011
    The battery terminals on your laptop are not making contact with the battery, that is why it is not charging, i will advice you try replace the battery terminals on your laptop.
  • Ishola Olayemi May 28, 2011
    Remove the battery from your laptop, plug the charger, see if the system will power on.
    Problem Solver:
  • 33 Answers
Try to check your charger tips and also the charging socket
Posted on Feb 27, 2015
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
My computer would not hold a charge and eventually stopped charging all together. I have tried a new battery and tried to charge on a different power card. Neither have worked.
if you have tried both a known working ac adapter and battery and still wont charge, then possibly, the issue is with the motherboard. You may need to replace it.
Jul 18, 2010 | Dell Inspiron 1525 Notebook
Battery won't charge dell inspiron 9300
either ur motherboard is shot or the port that the battery connects to on the motherboard is bad
Jun 12, 2009 | Dell Inspiron 9300 Notebook
My battery stopped charging
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try charging up your battery for more than 30mins. If battery is not charging for more than 30 mins, your battery is faulty.
Note: If machine is under warranty no need to pay for the re
Jun 03, 2009 | Acer Aspire 5570-2758 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Battery won't charge right
CHECK WITH ASUS FOR A NEW BIOS UPDATE. I HAD PROBLEMS WITH BATTERY CHARGING AND THE BIOS UPDATE FIXED IT.
Jan 11, 2009 | Acer Aspire 7720-4428 Notebook PC
No battery charging
you need to replace the battery.
Nov 12, 2008 | Lenovo 3000 N100 0689 Notebook
Battery will not charge
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
TechFuel® 6 Cell, Battery (SATUMT577) for Toshiba PA3817U-1BAS Laptop Logo
211 people viewed this question
Top TechFuel Computers & Internet Experts
justwinwin
Terry Schallert
Advaith Ganesan
Are you a TechFuel Computer and Internet Expert? Answer questions, earn points and help others
