My husband is looking for a book on Trigonometry and Logarithms. He says it should have lists of numbers. He is an Engineer. Is there such a book?
    Genius:
  • 1,267 Answers
Yes there is, as every Trig book for high school students from the early days had the log tables in the back of the book, they are still with us, even though many use the calculator instead of looking up the logs. There is a down loadable book at: http://ebookee.org/Trigonometry-With-The-Theory-And-Use-Of-Logarithms_201050.html
Many can be found at bookstores such as Barnes and Noble.
Posted on May 21, 2011
He needs a math tables book. They may not be published anymore, but try an old book store. Also search online for "math tables". This site has some tables http://math2.org/,
WT960 hotpoit washing machine shows F10 and stops
* F01 - Short circuit motor traic - Book a service engineer.
* F02 - Motor jammed or fan blocked - Book a service engineer.
* F03 - Front thermistor open/short circuit - Book a service engineer.
* F04 - No pump piloting - Book a service engineer.
* F05 - No feedback from the pump - Book a service engineer.
* F08 - Static heater relay with contact welded closed - Book a service engineer.
* F09 - Eeprom is not programmed or not functioning - Book a service engineer.
* F10 - Common of heater open or one shot open - Book a service engineer.
* F11 - No pump connection - Book a service engineer.
* F12 - Communication error between boards - Book a service engineer.
* F13 - Rear thermistor open/short circuit - Book a service engineer.
* F15 - Dynamic heater relay with contact welded closed - Book a service engineer.
* F-17 - Master relay welded closed - Book a service engineer.
Apr 06, 2015 | Washing Machines
What does the subscript between "log" and the
That's the base for the logarithm. Logarithms are usually taken with base 10 (common logarithms, LOG on the calculator) or with base e (natural logarithms, LN on the calculator), but sometimes other bases are used.
Feb 22, 2011 | Texas Instruments TI-83 Plus Calculator
How use the VAT
You have to print the vat number in bill books only.
1. You have to give the tin number at the places where you purchase goods.
2. You have to file returns monthly.
3. You have to keep an auditor to maintain records . Like purchase Bills and Sale Bills .
Jan 30, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
How do I find logarithms on the ti89?
For natural logarithms, you can use the ln function (2ND shift of the X key). For example, the natural logarithm of 3 is 2ND [LN] 3 ) ENTER.
For logarithms to other bases, use the log function (diamond shift of the 7 key). For example, the base-2 logarithm of 16 is diamond 7 1 6 , 2 ) ENTER. If the base is 10 (common logarithms), you can omit the comma and the second argument.
Apr 28, 2010 | Texas Instruments TI-89 Calculator
How can i get logarithms on the calculator
For natural logarithms Press [2nd][X], enter a positive number, close the right parenthesis and press [ENTER]. If the number is decimal the result is displayed as a number. If the number is integer, put a decimal mark at its end to have the result displayed as decimal.
For decimal logarithms use the ALPHA keyboard to enter the log( command, complete the argument and press ENTER
If you want to calculate log in base a of number b type log(b,a).
Apr 13, 2010 | Texas Instruments TI-89 Calculator
How to use the Logerithmic function on this calculator
Logarithms in base 10 :Common logarithms
  1. The calculator has a key labeled [LOG]. It allows you to calculate the common logarithms (logarithms in base 10).
  2. To calculate the common logarithm of a (positive) number you type in the number, press the [LOG] key .
  3. Ex: 15.32 [LOG][=] gives 1.1852558765
Logarithms in base e : Natural logarithms
  1. The calculator has a key labeled [LN]. It allows you to calculate the natural logarithms of positive numbers.
  2. Ex: natural log of 15.32 is entered as
  3. 15.32 [LN] gives 2.729159164
Hope it helps.
Don't forget to rate the solution and don't be stingy: 4 thumbs up won't leave you any the poorer.
Nov 23, 2009 | Texas Instruments TI-36 X Solar Calculator
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Hotpoint WF860
here is the list of code meaning from hotpoint.
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a service engineer
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer.
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a service engineer.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a service engineer.
  • F41 - Water level detect sequence incorrect. Book a service engineer.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a service engineer to re-programme your product.
please do not forget to rate and comment about your experience with fixya.
Aug 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    PHONE BOOK PROBLEM
    hi, There is possibility of duplicacy of ur husbands' Numbers on Phone memory, manually find the number of ur Husband in phone book & detete one.
    Sep 13, 2007 | Nokia 6600
    97 people viewed this question
    k24674
