Question about Simplicity Vacuums
We have a commercial Simplity vacuum series 6 and we are not getting any power. We tried different plugs, changed bag, etc. but still no power. Is there a reset button anywhere? Any other suggestions? Thank you for any assistance!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Check the reset switch on the back of the machine toward the bottom. Maybe next to a silver sticker.
If you need any help contact me.
Tim
TheVacCenter.com
Posted on Mar 13, 2013
5 Suggested Answers
advacak
  • 125 Answers
SOURCE: what bags do I use for Royal canister vacuum #3004
uses a royal or dirt devil type R bag
Posted on Dec 08, 2008
ukvacfan
  • 328 Answers
SOURCE: oreck 4080 the bag fell off the vacuum,
If the bag doesnt have a bag holder then the bags just push onto the black connector - there is usually a hook at the top of the oval connector where the bag once pushed on, sits over the oval dust channel feeder and locks into place. Once the Oreck is switched on, the bag in theory should stick to the oval hole.
Posted on Jan 23, 2009
SOURCE: Simplicity 7 Series Vacuum. Suddenly stopped.
There is a thermal reset button on your vaccum. It is on the rear of the unit, just below the attachments and next to the sticker with the serial numer etc on it. The vacuum is designed to turn itself of if too much heat gets built up to prevent it from "burning up."
Posted on Dec 29, 2009
  • 1206 Answers
SOURCE: i have a simplicity 6 series vacuum. the bag
no just on /off switch and direct power to vac motor sounds like its burned up from bag being overfilled , now you have to get to the vac motor test it with switch on to see if its getting power if so then motor is burnt.use an ohms meter for power test.
Posted on Feb 07, 2010
Sentry 3 series vacuum smelled hot, and now will not power up, changed bag (not over full)
There is a reset button on the back of the vacuum that shuts the power off if the motor gets too hot. Try pushing the little white button on the back. If it comes back on that means that there is probably a clog somewhere or the bag was too full.
Aug 10, 2013 | Simplicity Vacuums
Where do I find the bags for this old c1403 one?
Were these generic bags or Hoove brand? Also, I believe that some bags have a rubber seal on the inside of the hole to attach. I hope this helps. Type A is the correct one.
Apr 21, 2010 | Hoover Commercial C1403 Bagged Upright...
I have a simplicity 6 series vacuum. the bag overfilled and vacuum will not run. No power. is there a fuse of relay inside the unit?
Feb 07, 2010 | Simplicity 7250 Deluxe Vacuum
The bag was full, it has been changed - still no power when plugged in
It sounds like you have carpet fibers and lint that are stuck in the motor carbon brushes. That is common on this machine. You will have to take the motor out and have it thoroughly blown out will an air compressor.
Dec 11, 2009 | Hoover Commercial C1403 Bagged Upright...
No power for the vacuum
Hi! I work at repairing Sebos, so can certainly help.  Most probably the cable is damaged, and the two most likely places for that to happen are where it enters the plug and where it enters the rewind mechanism. Before you even think about dismantling the machine to get at that end of things, though, you need to be 100% sure that power is reaching the machine.
I know you've tried a different socket, and that you've changed the fuse (by which I assume you mean the plug-top fuse, and therefore that you're probably in the UK like I am). Good first steps. Checking the integrity of the wire in the cable is a different matter, though. There are inexpensive devices you can buy to check for voltage through normal insulation, but I don't know how deep in to this you want to get...  you've got to be pretty keen (and competent) to think of changing the cable yourself.
If you'd like to post a response, indicating how far you want to go yourself, I can help you get in to the machine if necessary.
May 25, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Need owners manual for kirby ulitmate g series
Here is an online guide that will get you through the belt change process...you will also find manuals available. Hope this helps...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jan 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
136 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
