Question about Maytag Bravos 3.8 Cu. Ft. Washer
Ul code sheets are balled up machine stops working, bought 2 mos ago
  • Maytag Master
  • 8,220 Answers
Unbalanced load. Common problem when washing fitted sheets. The Appliance Assistant wrote an outstanding article about the problems associated with these machines and the solution! HERE
Posted on May 21, 2011
  • Dan Webster
    Dan Webster May 21, 2011
    In case you didn't want to read the whole article:
    Balance Tip: Fitted sheets can sometimes turn into a large heavy ball as they collect other items inside themselves during the wash cycle; this ball is nearly impossible to balance at 1000 RPM. Solution…don’t wash fitted sheets with heavy items like towels or blankets, and stay close while the cycle is active so you can stop the cycle and readjust the load if necessary. As a general rule towels should only be washed with other towels and heavy items that can be properly balanced. If you wash a bunch of shirts with on big towel the load will go off balance almost every time.
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
My WTW7600XWO washer stops with 11 minutes left to go and UL comes on
The UL code means that the load is unbalanced. With the Cabrio washers, frequently this is due to the failure of the suspension rods that hold the tub. To check this, use a putty knife to separate the clips that hold the top of the washer at the front of the unit. Then lift up the top. Check the suspension rods and balls. Also check the wiring at the motor and the control panel, just to rule out any electrical cause for the UL error. You probably only need to replace the suspension spring kit, W10247710, is available from several sources, including: http://www.appliancepartspros.com/whirlpool-suspension-spring-kit-w10247710-ap4411122.html . There are videos showing the the replacement procedure available online.
I hope this helps.
Jul 09, 2015 | Washing Machines
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the message ul mean?
The UL code means a unbalanced load,sometimes it can as easy as leveling the washer,or a odd load such a towels all being on one side of tub and thinner less water retaining sheets being on the other side.
Gene
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The Washing Machine Is washing but not spinning and The electrical panel on the front of the machine is saying UL .
UL is a code for the load being unbalanced. If the load is evenly distributed, open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't spring up. Look for rust around the suspension points at the top of the cabinet. The rust, if present, has likely fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. Automotive wheel bearing grease with graphite in it works well, but any will work. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around and became off balanced. This should take care of the unbalance code.
Jan 12, 2011 | Whirlpool Washing Machines
I have a Kenmore Oasis HE model 110.28082700. On any setting, it will run though until it reach the spin cycle and then it drains, stops, beeps and flashes the ul message and shuts down with about 6...
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) because of "LU" Error code. First test run and now "LD" error code... So not sure I will buy another Kennmore in the future...
Jul 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
I have a Whirlpool Cabrio top loader. My wife is going crazy with the unbalance of the unit everytime she puts in sheets. They ball up and the system shuts down with code of ul. She then has to open the...
call servce possible issue with control board program problem senses off balance too easy.. also supposedly there is a redesigned wash plate that helps
Apr 25, 2008 | Washing Machines
UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Bravos 3.8 Cu. Ft. Washer Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
