Question about Garden
My neighbor gave me her hozelock pond filter, it is the cyprio box filter, it also has the light that keeps the water from turing green, she can't find the instructions on how to hook it up, i have the filter box together & the hoses to hook it up with, but don't know how to hook up the pump to the filter ,could you please show me how to put it togather so i can stop the water from turning gren, are send me a copy of the in structions for it, if you need more information on the product please let me know. thank you ms jackson
clyde2j2
  • 137 Answers
SOURCE: How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Posted on Mar 28, 2009
  • 10865 Answers
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
Posted on May 02, 2009
SOURCE: Hozelock Bioforce 9000UVC pond filter. Do I put
Yes usually one goes from the Coarsest, first and out to finest on top.
Posted on May 06, 2010
Testimonial: "That was quick. Many thanks for the solution to my problem."
  • 7 Answers
SOURCE: Hi, I have a Hozelock
Hi - I'm Simon from Hozelock. There should be a big o ring that goes between the lid and the tank to make a seal - is that missing ? Also there should be clips that hold the lid to the tank. Both pieces are available as spares, at www.hozelockservice.com - any probs contact info@hozelock.com or @hozelock (twitter) or Hozelock on Facebook. Best wishes.
Posted on Feb 26, 2011
  • 56 Answers
SOURCE: dear sir i have a
It sounds like the pump is overheating, this can be caused by a few things. First check the filter for clogging and also while you have the filter casing open take a look at your impeller. Gently turn the impeller to check if it is jammed, it's ok if there is a little resistance from the magnets but it should turn readily. If the impeller feels like it is grinding or sized you can try to gently remove it from the housing. The impeller is attached to a barrel shaft made of magnetic material that will wear down over time and is replaceable. If everything on the intake end seems normal, we check the output line for clogging or restricted flow. To detach the output line from the main unit simply unscrew the pressure bolt at the base of the output pipe. Open the valve on the output pipe and probe the pipe for clogs using a probe (a bit of wire coat hanger will serve just fine). Gently probe for a soft mass that will feel very different than the plastic. If you do feel a clog simply bend a small hook in the top of your probe and carefully snag and extract the clog.
If after these steps you fail to locate the issue most likely the issue is with the motor and the unit will need replacing.
Posted on Mar 17, 2011
Hozelock bioforce revolution filter
yes you can buy them
http://www.hozelock.com/our-products/aquatics/bioforce-revolution/
May 19, 2016 | Hozelock Garden
Can you help me my garden pond keeps going murky i have 2 ultra violet lights in it i keep changing my water but does not get any bettter
26 fish is a lot unless it is a big pond. Cold water fish create a lot of detritus. Do you have a fountain to aerate the water? Margin plants will also help. You could also add a pump and filter. I found this unit for you.
http://www.hozelock.com/aquatics/filters-and-uvcs/easyclearfilter/easyclear-6000--1-240.html
Aug 23, 2015 | Garden
Need instructions on how to install hozelock cyprio filter & pump
need instructions on how to set up filter, hazelock cyprio please
May 21, 2011 | Hozelock Cyprio Prima Xl 3400 Gph Pump
I have a brand new hozelock easyclear 6000 pond pump. When I plugged it in.....nothing!. Outdoor electrical socket working ok. The pond is newly built so their are no leaves or sludge in the pond, in-fact...
Sorry to hear of your setback but hopefully we can get you back to worrying about your pond occupants rather than the equipment. First remove the filter cover and filter and give the impeller a gentle turn to feel if the bearing or motor is jammed. If it turns freely try powering the unit to check if the impeller turns, sometimes the impeller needs a little bump to get it moving at first. If nothing still happens return the pump for a replacement.
Mar 28, 2011 | Imperial Garden Products OSI Submersible...
Hi, I have a Hozelock Cyprio 1313 filter I inherited with my pond and new house. I Cant seem to get it working without water pouring out the two holes on the top and elsewhere. I'm not sure if I am putting...
Feb 25, 2011 | Sport & Outdoor - Others
Hozelock 1313-0000 pond filter, clips won't clamp
I have exactly the same unit as you and also suffered the seized clip problem. I found this was due to debris (fine grit) getting lodged under the clip hinges ands the easiest way to get rid was to flush it out with a high pressure water jet. also you need to make sure that the large "O" ring is seated properly. The clips latch easier when a downward force is placed on the top.
Hope this helps.
Jun 05, 2010 | Garden
I have a hozelock bioforce filter that i have
Sounds like the the bypass valve may have been disturbed and so water is coming out of the air bleed hole.
I suggest you turn off the pump, remove the bypass valve cover (clear part that quater turns off bayonet style), extract the red valve (careful not to lose spring), rub some pertoleum jelly (vaseline) around the seal of the red valve, replace spring, red valve, press the red valve a few times to ensure it returns, replace clear cover and turn pump back on.
This should ensure the valve is working.
May 23, 2010 | Hozelock Garden
Hozelock Bioforce 9000UVC pond filter. Do I put the coarse filter in first?
May 06, 2010 | Garden
How do you change the uv bulb in a hozelock vorton 2200
remove the 2 screws at the end of the unit and pull the end off.the bulb is attached and will come out with it.pull the bulb out uf the holder and replace.(on mine the screws have 2 differnent heads on for some unknown reason)
Apr 18, 2009 | RTO Vorton UVC500 Clarifier For 500gal...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
