Question about Acomdata (HD080U2FE-72) 80 GB Hard Drive
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How can I reciver the data?
    Scholar:
  • 106 Answers
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
Posted on May 21, 2011
  • r_mcdonne64 May 22, 2011
    I disconnecting and reconnecting and rebooted with no success. I also tried to connect to my laptop (Toshiba w/Vista) and got the same results. I don't currently have a firewire cable.
  • Eli Elle May 22, 2011
    Alright.
    Make sure you are trying to connect it to a 2.0 USB port.
    Have you used the drive before ever? have you been able to use it before? If you have,
    try to lug it in the same port. Sometimes drives dont want to be switched between ports.
    if it has it's own power adapter, please make sure this is plugged in, cause the port itself cannot provide enough power.
    if it is a desktop PC, then try to connect it to the ports in the rear, not the ones in the front.
    ONLY use the USB cables that came with the drive. other usb cables (eventhough all look the same) might not be compatible with your drive.
    if all else fails, there might be a problem with the USB cable itself. Try another cable or See if you cand borrow a firewire cable from someone and see if it will solve the problems.
    please rate the answer if it was helpful. Thank You!
My storejet isn't recognized in the computer but the light is on
check it on some other usb port or in some other system if the result is the same then replace the usb cable, then check
Jan 27, 2013 | Transcend StoreJet 25 Mobile 500GB USB 20...
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
Failure to turn on
Sounds like either the power cord for it went bad or the drive died.
Jun 14, 2012 | Western Digital My Book Essential 1TB...
I dropped my drive and now the computer won't recognize it. The blue light is on with the red light. Help!
Sorry to hear that your drive is having trouble. When you start the drive, do you hear it turning?
Is this a external that you can remove the hard drive? You may try to power down the external, power it back up and shut down your computer. The conect the external and turn the computer on.
Let me know if you can hear the driver turning and it you can connect after going thru the process above.
Brian
Feb 05, 2011 | SimpleTech Signature Mini 320GB External...
Twin drives in an external HDD, and it quit, but I can hear them working. The fan also quit too.
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware
May 20, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computer suddenly not recognizing relatively new WD MyBook 640GB
Just a shot in the dark, but ..., shut down your computer and unplug the drive. Turn the hard drive off, then back on. Plug it back into the computer and restart. If it doesn't pop up, restart your computer this time with it plugged in.
Is there any noise coming from the drive? Is the green light on the front?
The same thing happened to me and the same drive, but 500gb. I did the above and it fired right back up again. You may have to delete the trial version from the drive if it on there, or from your computer if you had originally installed it.
Jan 07, 2009 | Western Digital 320GB MyBook External USB...
Not being recognized now
It wasn't a malfunction of the simple tech unit, the problem was with the computer itself. I finally re booted the computer and the problem resolved itself. Thank you for being there and I learned a bit out of the experience (I am new to mac's)
Nov 15, 2008 | SimpleTech Signature Mini 160GB External...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Acomdata (HD080U2FE-72) 80 GB Hard Drive Logo
310 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
