Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less than half of letter. have not replaced the print wheel.
  • IBM Master
  • 3,594 Answers
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Posted on May 23, 2011
  • barbaraek May 24, 2011
    A repair man had come in and that is exactly what he said. The platen was just loose enough that you didn't see it.
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
Typing half letters
If it was working befor you changed the ribbon check to be sure the ribbon's feet are engaged in the slots on the ribbon deck, that the blue latch is latched and there isn't a fold in the ribbon. If all of these are OK push down firmly on both ends of the platen.
DickyO
Feb 16, 2010 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 30 series 2.
Put in a multi part form and type if the print is good on the carbons the problem is ribbon or ribbon lifting, if the print is poor the print solenoid cap is probably cracked. We sell the cap with instructions and shipping for 20.00.
DickyO
216-241-0027
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
Only part of a letter appears when typed
You can try code I to increase the impression but probably the print solenoid is gummy or the plastic solenoid is broken. We sell the caps with installation instructions for 20.00 includes freight. DickyO Cleveland Business Machines 216-241-0027
Jun 15, 2009 | IBM Wheelwriter 30 Typewriter
Only part of the character/letter is showing
make sure the ribbon is latched into place (should lock down) also check on the ribbon itself to make sure the print is in the middle of the ribbon and not on the very bottom, if the ribbon is locked down and types of the bottom of the ribbon, it is out of adjustment. if the ribbon looks ok, move the paper scale (the plastic piece on top of the platen) up out of the way, then push down sharply on the platen. if it moves down and clickes into place, it should work OK.
Jan 05, 2009 | Lexmark Wheelwriter 15 Series II...
My IBM Wheelwriter III does not print the letters. I have replaced the ribbon but still no letters. Please help. Thanks.
rub your finger over the ribbon if no ink on fingers then your ribbon is dry little solution for old ribbons is cotton and little water over ribbon not too much
May 07, 2008 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
321 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
