Question about GPX D200B Player
Attaching D200B to TV using color coded RCA audio/video cable. set TV to channel 3. set TV to DVD. power on DVD player. insert dvd. DVD player appears to be working. But contents of DVD not showing on the TV.
  • GPX Master
  • 6,993 Answers
I think your connection is wrong that's why the content of your DVD is not display on your TV. Cross check your connection by reading further....
The RCA cord has three wires. I'm sure you are aware of this.... The wires are yellow, white and red.
The yellow cord is responsible for display, while the red and white is responsible for sound.
Look at the back of the TV, connect the yellow to "video in", then the white and red to 'audio in'.
Connect the other end of the RCA cable to 'video out' and 'audio out' respectively at the back of your DVD player.
Now, press source/AV on the TV and there should be a display of the DVD on your TV.
Now you are through.
Let me know if this doesn't work for you so that I can look further into the issue.
Regards.
Posted on May 21, 2011
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
How to connect an LG26LE3300 TV to a Humax PVR-9200T and to an Inventive DVD video player? These worked fine with my old TV using scart cables but not with the LG.
You will see the colored jacks on tv. There should be a print by them that says out. Match the colors from the jacks on the tv to the same colored ones on the Humax. The ones on the Humax should say input or a/v or dvd, or phono. From the dvd player, match the colors from here to the tv. The tv should have another set of 3 colored rca jacks that say imput on them.
From DVD Player out to tv in From tv out to Humax in/av/dvd/ ect.
Yellow is video Red is Audio Right Channel White is Audio Left Channel
Jan 14, 2011 | LG Televison & Video
How do I hook up a dvd player?
Hello Andy, Hi!, you can hook up your DVD in 3 ways. 1. using standard RCA cables, 2, using Svideo cables, and 3. using HDMI cables. Depending on your player. I suggest you buy the RCA cable. they are color coded so the yellow goes to the player Video out to the TV video in, red and white cables goes to the Left and Right channel of the player audio out to the TV audio in. thats it.
Dec 21, 2010 | RCA F27242GY 27" TV
How do i attach a dvd player to my tv
First, get a set of composite Video/audio cable, it will have Yellow (Video), Red (Right channel audio), White (Left channel audio) with RCA plugs at both ends.
You can choose AV1 input at the back of the TV, all you have to do is to match the RCA jacks on the back of the TV to the color of the RCA plugs, same for the connection at the DVD player.
Set the TV to AV1 and watch you DVD.
http://s807.photobucket.com/home/budm/allalbums
Jun 17, 2010 | Samsung LN-T2353H 23 in. LCD HDTV
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Will not work
Hi, you'll want the 3 colored RCA cable to hook this up to an older TV.  Yellow is for Video Out on player and Video In on TV.  Then, on player, correspond the red and white to their holes for Audio Out, and match them with Audio In on your TV.  You may have 2 spots on your TV that are labeled Audio In.  Try them both - the one that works should very close to you Video In line.
Hope that helps!
Dec 07, 2007 | Protron PD-800 DVD Player
GPX D200B Player Logo
171 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
