Question about Hayward SAND FILTER, PRO SERIES
I need to know how much sand in my filter GM Series 142ABK
  • 6 Answers
SOURCE: replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Posted on Jun 09, 2009
jharwell668
  • 640 Answers
SOURCE: no suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
Posted on May 24, 2010
jharwell668
  • 640 Answers
SOURCE: HAYWARD SAND FILTER, PRO SERIES: sand is getting into the pool whan the filter is r...
Have you tried backwashing recently? If so, I would first check to make sure that your pool filter is on the "filter" setting and has not been changed. Next, i would evaluate your filter pressure to make sure that it is at an acceptable level. Finally, check your sand. If it is extremely dirty or has not been replaces in a long time, it might be time for fresh, more effective sand.
  • 760 Answers
SOURCE: I have a leak in my above ground sand filter,
Usually in th bottom of the filter you have two parts. The first is a piece with a screen that threads into the plastic housing. The second is a Cap with a rubber washer inside. Make sure the rubber washer is there. Do not overtighten the drain into the houseing
Posted on Jul 25, 2010
Testimonial: "Thank you sooo much. "
StepehnD
  • 78 Answers
SOURCE: Does the Hayward GM-245 Sand filter tank separate
I am not that familiar with the G series Hayward filters, but most sand filter tanks do not separate. It's a labor intensive job so think hard before trying it if you haven't before. If your backwash valve is on top of the filter, the plumbing will have to be removed. There are two ways that I have removed the sand. Scooping it out by hand or using a shop vac. Remember the sand is going to be very heavy when wet. You will need to go through the top. Some filters have a large drain plug in the bottom that "supposedly" you can drain the sand out through.I have done this once and it makes a big mess that you still need to clean up.
Be sure to buy replacement o-rings and gaskets as needed. There is also a product called a sand vac that is in essence a siphoning system.
Be careful not to damage the laterals it the bottom of the filter. When replacing the sand, I put small gravel (pea gravel) carefully under and partially around the laterals to help support them from the weight of the new sand.
When you are done, be sure to backwash the new sand to remove dirt, impurities, etc. This is a general overview. There are books online that give more detail or use a similar filter's manual...
Posted on Jul 27, 2010
I have a hayward sand filter pro series and for some reason the water from the pool keeps draining I need to know if the switch at the top is at the right direction
check to see if water coming out of backwash valve while if filter position bad multiport gasket you can put a valve on it and close when not backwashing
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
How much sand do i need in the sw 196T
look at label on filter it will tell you
Jan 25, 2014 | Hayward SAND FILTER, PRO SERIES
We need to change the sand in our filter ,it is a sw256t hayward ,but dont know how to remove other sand,does anyone know how?
Once you have the plumbing disconnected and valve removed,
Use a shop vac. Works well.
Once the sand is almost all removed, you can tip the tank over & rinse out with hose for the rest.
Jul 28, 2012 | Hayward Pro Series 18" Above Ground Pool...
Water comeing out cloudy and makeing suds in pool
There could be a few things causing these problems. How old is the sand in the filter? Filter sand looses its filtering ability after 3-5 years and needs to be replaced. If the sand needs to be replaced, make sure you get actual pool filter sand. A lot of big box and home improvement stores sell play sand as filter sand. That will cause your pool to stay cloudy and never clear up. If the sand is less that 3-5 years old, you may need to clean it with a liquid filter cleaner that is poured through the skimmer. This works quite well!
Another issue causing the cloudiness and bubbles could be the type of chemicals you are using. I know that shock from big box and home improvement stores cause the water to be cloudy. Algaecides from these stores also cause foaming.
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
I have a leak in my above ground sand filter, model 140. the leak is around the drain. How can I fix it? It is a Hayward, high rate sand filter, GM series, model 140ab. Thank you
Jul 24, 2010 | Hayward Pro Series 18" Above Ground Pool...
Hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
I bought my above ground swimming pool package in 1990. My Hayward sand filter is a top mount and has a lateral assembly w/center pipe in side of it. The pipe is broken at the top and I need to purchase a...
I believe that the owners manual has a parts listing to help you distinguish the part that you will need to buy. However, if your pool filter was purchased in 1990, you are probably going to need a new filter. Most do not last over 20 years.
May 01, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
159 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
