Question about Dometic RM2652 Refrigerator
Poor cooling fridge
Hello, My Dometic fridge freezes; however, the fridge only drops to about 45-60 degrees F depending on the weather outside. Thanks Tim
  • Anonymous Mar 13, 2014
    New adjustable thermister by ARticca NO CHANGE STILL FREEZES IN FRIDGE FREEZER VERY COLD ?
  • 51 Answers
Small slide control inside of the fridge. Think of this as your knob control on house fridge. Slide it up and down the silver coil to adjust temp in the lower unit.
Posted on Sep 07, 2008
We have a 2016 Montana 5th wheel with a Dometic refrigerator. The freezer works fine but the refrigerator will only cool to 40 degrees. We would also like to change the stainless panels to black
$0 degrees is about right. If you go much lower towards 32 you will have stuff freeze on you in fridge compartment. Maybe your thermostat is shutting off compressor prematurely and you can try replacing it with another.
Aug 28, 2017 | Dometic Refrigerators
Dometic Frige RM2611 stopped working when extreme cold weather set in
Yes they are designed to operate in a conditioned space. If it has a condenser fan motor you could put a cycle switch on it and that would extend it's operating range
Dec 10, 2013 | Dometic Refrigerators
Coleman 8000 compressor only comes on and cools when cool outside like in Am or late pm
Clean the coil inside and outside. try putting it in a window on a shady side of the house. I worked on a outside unit wher it was 90degrees outside but 107 degrees where it was in a hot location, close to road on sunny side of house.
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
Everything freezes, model 2652 dometic americana
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Sep 14, 2011 | Dometic RM2652 Refrigerator
Dometic rm2652 fridge section freezes everything
Hello Keith,
Just came across your question, hope its not too late to answer.
Your freezing problem for the fridge section is likely caused by
1) the thermistor has worked itself loose from the cooling fins.
2) the thermistor is no longer on third fin from the right
3) the thermistor is failing.
Jun 26, 2010 | Dometic RM2652 Refrigerator
What may cause the outside copper lines to freeze ,the refrigerato is cooling but i notice water comes out from underneath at the floor.
This is normal if the weather has been hot and humid. There is a "drip tray" that can be pulled out from underneath the front of the fridge if its full the water will poor on to floor. If the fridge is running all the time check your door seals and make sure the door closing properly as this will also cause the same problem.
Sep 07, 2009 | Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Dometic RM 2804, freezer is ice cold, fridge is 60 degrees to warm for food
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Aug 22, 2008 | Refrigerators
Our Dometec refrigerator in our 2006 Fleetwood Sequoia pop-up camper is giving us problems. Sometimes it will cool to 32 degrees. Other times we can't get it below 60 degrees. We've checked for yellow...
It can have something to do with the wether. As it gets hotter you need more air flow on the back to pull the air up and away. You can add a fan just like the one on a computer. Also make sure the thermister inside on the coil is attached tightly to the fins in the back of the fridge. The control boards have been known to work with an inttermitent problem. The worst thing is you could have a floating blockage in the coil if this is the case it will happen more often and eventually stop working.
Aug 16, 2008 | Dometic Refrigerators
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
448 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
