2003 Kia Spectra Logo
Posted on May 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to take the passenger door panel off of my 2003 kia spectra however it still seems connected towards the front side of the door but i tryed to removed the two tan screws just free spin i do not believe they are attached i didnt want to just pull it and break it
  • Igor Schmidlapp
    Igor Schmidlapp Mar 24, 2019
    They aren't screws, they are push-in fasteners that look like screws.
    You can pry them out. Pry them out a little gently, then loop a string around it, and you can yank them out. They just push back in. You can get replacements online. The beige are part #KK344-6852575.
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on May 21, 2011
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439488
Points
3355
Disconnect the negative battery cable to prevent shock when handling the door components. Loosen the cable's nut with the pliers and slide it away. Pop off the side-view mirror interior panel with the tweeter on it. Use the door panel trim tool or a flat-bladed tool, such as a putty knife, wrapped in masking tape. Once the panel is off, unplug the speaker connection from behind it. Push the connector's tab in with a flat head screwdriver and pull the connector away. Open the door fully to expose the screw cover on the front part of the door panel. Pry out the screw cover with a flat head screwdriver. Pry out the small centerpiece; not the ring surrounding it. Behind the cover, you'll find a Phillips screw; remove it.
Open the screw cover flap behind the inside door handle. Insert the tip of a flat head screwdriver into the upper-slot; push down to open the flap. Remove the Phillips screw from behind the flap. Pull off the plastic door handle surround piece. Insert the door trim tool behind the panel; pull it back to pull the panel off. Slide the surround piece away from the door panel.
Remove the circular screw cover from the inside door pull storage compartment. Pry it up with the flat head screwdriver. Remove the Phillips screw behind the cover. Remove the screw cover from the rear-edge of the door panel. This cover is similar to the one on the front part of the door panel; pry out the center part, not the ring surrounding it. Remove the Phillips screw behind it.
Remove the two Phillips screws visible along the bottom part of the door panel.
Pry around the perimeter of the door panel with the door trim tool. Pull the tool handle back to pop the door panel clips out. Do this for each side, except for the top. Once the clips are unhooked, the panel is ready for removal.
Gently pull the door panel away from the Optima's door, but only enough to access the area behind it. The connections for the power equipment must be unplugged. Reach around and depress the connection tabs with the tip of the flat head screwdriver; unplug the connection. There are three connections to unplug. Once they are unplugged, pull the door panel away.
Thanks
How to Unlock front doors on 2003 Kia Spectra.They are not electric. Locks are NOT electric.
These might sound like silly suggestions but I've done this. Have you tried unlocking both doors? It might unlock just the passenger door but you will be able to reach over and open the drivers door.
If yours is the hatchback version have you tried unlocking the boot lid and climbing through the car? I think some models of the saloon have a release to drop the rear seats on the back of the seat panel so you could climb through that way.
How hard is it to replace a passenger side mirror on a 2003 Kia Spectra? Non heated and manual mirror.
ITS NOT HARD AT ALL REMOVE THE BLACK COVER IN THE UPPER CORNER OF DOOR JAUST CLIPS IN AND REMOVE THE 10MM BOLTS HOLDING IT IN 3 OF THEM GOOD LUCK
What would cause an 03 kia spectra stereo and interior lights to go out
sounds like you have a blown fuse look in the fuse box the one thats inside the car and find the fuse for the radio and or the interior light they may be on the same fuse the box should be in the dash if not try on the drivers side down by the front of the door jam. or kick panel
3helpful
3answers
I have a 2005 kia spectra. The power door lock,
dirty solonoid inside the door ,take door panel off and give everything in sight a good oil with a proper oil can with engine oil in it ,also check the mechanism from the barrel to the electrical switch because a bit of plastic could have broken off where it turns to operate the switch that works the central door locking
2helpful
Where would the fuel filter be located on the 2004 kia spectra (4 cylinder-1.8)
Under the car, passenger side, toward the back of the car, ( some models have it under the back seat). Shaped like a soda can with 2 or 3 connections to it.
2answers
Can't get passenger side marker light out on a 2007 kia spectra
There is one bolt on top of the radiator support and another in back. The assy fits into a pluug that keeps it aligned so it cam be tough to remove. Just wiggle it side to side while pulling and it'll slowly come out.
Are you looking to fix the bulb that is in the corner of the headlamp? You don't need to remove the head light for that. The is a black cap that screws off just beind it.
My 2007 kia spectra's door lock themselves
it may be centrally locked on the driver's control switch.
Cant get front drive side door panel off
they are held by plastic type rivets..you have to gently tug from the bottom corners and work your way up ..dont pull too hard or you might damage wiring, make sure all screws around arm rest are off and door handle, this is where manufacturers tend to put screws in.
1helpful
No power on front passenger door
Check the connections between the door and the body, not the panel on the door. If a wire was pinched between the door and body that could be the problem. There should be a boot between door and body, peal that back and look for damaged or grounded wires. Repair as necessary.
Joel
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
