Question about Hand Tools
My stihl f55 edger stalls when giving it gas. Cleaned spark plug. Could it be bad gas or something else?
    Sergeant:
  • 207 Answers
Try cleaning or replacing the air filter, it might not be getting enough air to sustain combustion.
Posted on Jun 06, 2011
Stihl weedeater stalls when I compress throttle trigger
dump the fuel --clean air filter-change spark plug-- use new fuel synthetic 2 cycle oil--93 octane
Oct 11, 2014 | Stihl Garden
Why won't my trimmer start?
suspect a bad carb... but you didnt mention a model number... if it's a four mix it could have other issues
Aug 28, 2014 | Stihl Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Stihl fs85 gives off white smoke while running
change to stihl ultra oil and make sure you ratios are correct. also replace spark plug and spark arrester.
Oct 07, 2012 | Stihl FS 85 Weed Eater
Can't start my Pe550 Gas Edger. I cleaned the air filter. I'm having trouble getting the old spark plug out to replace it. How do I do it, and what else could be the reason for it not starting?
Hello rne.... Take your edger to any auto parts store and either borrow or buy the correct spark plug wrench to remove it. Have them remove it for you to check it and see if you have any serious problem that a bad spark plug might show. Then purchase a new spark plug, have the store gap it and install it. They do this fo no fee.
Once you have a new spark plug, new, fresh fuel with oil added to the fuel mix, and your clean air filter your edger should start right up. If it doesn't get a can of starter fluid, give the air intake a couple of squirts and start it up. If it stalls again get a helper to spray more starter fluid at the air intake until you run it for at least a full minute on the starter fluid. That will clean out any crud that is causing your troubles. Joe
Jul 12, 2011 | Poulan Pe550 Gas Edger
When i give my stihl weedeater (fs 55) gas it dies. i changed the gaskets in the carburetor, new spark plug, new air filter. it idles fine just when i give it throttle it dies
This could be from a bad fuel filter (has a dark appearance when dry), from the spark arrestor screen in the muffler being plugged up with carbon deposits (take out the spark arrestor screen and clean it by burning off the carbon deposits), or the carburetor needs to be adjusted. If the carburetor needs to be adjusted I would take it to the nearest Stihl dealer that has a Gold Certified Technician. That way the unit is adjusted properly and is in good running condition. You can find a local dealer with the dealer locator. The link is HERE.
Mar 19, 2011 | Garden
Stihl FS85 Stalls when warm and gas is given will still idle
Make sure the carb settings are correct. Screw both tuning screws all the way in and then turn ot anticlockwise the following settings H 3/4 of a turn, L 1 full turn. (this is set to the standard setting)
Jul 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
May 14, 2009 | Garden
The trimmer will not run when i give it gas
When 2 cycle engines preform as you have stated...the main problem is a carbon build up on the spark arresting screen on the muffler, it needs to be cleaned or replaced with a new one
Apr 04, 2009 | Garden
Hand Tools Logo
175 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Dan Apthorp
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
