Question about Hitachi 51F59 51" HDTV Projection Television
Red screen when I turn on the tv the picture is red what do I do? Is there a upgrade for my 51F59A and how do I correct the color back to picture perfect?
  • 2,326 Answers
Here is the illustration of the focus control.
Posted on Aug 15, 2008
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
When I turned the tv off last night the picture was fine, but this morning when we turned it on this morning, the picture is very dark and mostly blue. 51F59A, purchased in Dec 2006.\r\n Thanks for any...
If you turn the tv off for about 1020 seconds, turn it back on and see if you have a clear picture, if not it sound like a power supply problem in the tv. but if that did not solve the problem, the picture board on your tv is now malfunctioning or as gone bad, it means the picture board of your tv has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your tv to solve the problem.
Nov 28, 2010 | Hitachi Televison & Video
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
51F59A model hitachi rear projection tv
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
Jun 11, 2008 | Hitachi 50V715 50" Rear Projection...
Screen colors not constant
You probablly have bad solder joints on your Video driver transistors, which arre located on each Picture Tube. You can only get to those by going through the front, grille cover
Apr 10, 2008 | Pioneer SD-P62A5-K TV
HITACHI 51F59A PROJECTION COLOR TV
we have hitachi 51 inc projection tv model 51f59a for 2 yrs. we got problem adjusting the colors the screen is reddish. pls solve this .
Jan 08, 2008 | Hitachi Televison & Video
Upgrade for Hitachi 51F59A
The slot in the back of your TV is for upgrading the software version . It is like flashing the bios on a computer. If you are
having HDMI issues such as loss of audio, audio out of sync, color problems, intermittant shut off, snowy pix Etc. you may have to upgrade. Hitachi is aware of certain issues and they have downloads available to solve conflicts as they are identified.
Nov 05, 2007 | Hitachi 51F59 51" HDTV Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
238 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
